00 in cab vent controll
Old Sep 10, 2008 | 09:12 AM
Jimbo455's Avatar
Jimbo455
Default 00 in cab vent controll
Hello, new here just found the site while looking for an answer to my problem.
I have a 2000 Dakota Quad cab and the issue is I can not find a setting on the HVAC control panel that stop the flow of air into the cab. There is always what seems to be outside air coming through the vents? Everything else seems to be working fine. I was hoping to find a diagram of the heater box that would show were all of the doors and controls are but I have had no luck as yet.
Has anyone ever seen or heard of this issue before.
Thanks,
Jim
Old Sep 10, 2008 | 10:06 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
there is a setting all the way to (i think its the left) that says MAX settings this a reciurculation setting were it iwll pull air from inside the cab instead of from outside i hope this is the solution you were looking for
Old Sep 10, 2008 | 10:17 AM
Jimbo455's Avatar
Jimbo455
Thanks shrpshtr323, I have three controls Top one is for Fan speed, center is for Off/AC/Heat/Defroster and the lower one is for Temp.(cold/hot).
With the center control to off there is no fan running but as the truck is moving down the road there is a far amount of air that is blowing in through the vents. I am thinking that something is disconected but without a diagram I am not sure were to look?
The only thing with that above statement is that everything else seems to work fine???
Jim
Old Sep 10, 2008 | 02:43 PM
f0x672's Avatar
f0x672
its all electric, your vent position determines if it's outside circulation or internal circulation, the ones that say MAX are for internal circulation. this design saves space on the dashboard. you're gonna have leaks regardless, this isn't a bmw
Old Sep 11, 2008 | 08:57 AM
shrpshtr325
THE ULTI-MOD
lol even a bmw isnt perfect but ya as long as its not like fan force air moving in its just leaks but you can try just setting it on internal circulation to cut down on airflow
