Need more mods!!
Old Sep 11, 2008 | 09:57 PM
Spike300's Avatar
Spike300
if u wnat that much power just go with an engune swap haha, but yuea cams, spring, rockers, well all the engine guts
Old Sep 12, 2008 | 01:03 AM
vanner77's Avatar
vanner77
i have seriously thought about it. but i like to push an engine to its limits using alot of the stock components. also i work at honda and really wanna tear up all the little civics they drive haha but yeah im keepin my 4.7 and gonna build on it.
Old Sep 12, 2008 | 01:19 AM
f0x672's Avatar
f0x672
the 4.7s have a lot of potential, just need the proper work and parts
Old Sep 12, 2008 | 01:41 AM
varsis's Avatar
varsis
Bore and stroke it. That should give you plenty of improvement... Maybe some custom cams with ported and polished heads.
Custom intake 4 brl.
Throttle body Some nice one.
High performance ****.
Old Sep 12, 2008 | 02:25 AM
Rakaric's Avatar
Rakaric
and $$$, lol. if only i had a million dollars... as a matter of fact...I'd probably not even live in a house. I'll just live in a big garage with a room or 2. That and a big yard is all i need. I wouldn't mind working on cars all the time.
Old Sep 12, 2008 | 02:59 AM
varsis's Avatar
varsis
Lmao!!
Old Sep 12, 2008 | 04:26 AM
User's Avatar
User
start with upgrading the intake manifold and cams to H/O
should be good for a few extra horses.
Old Sep 12, 2008 | 09:40 AM
vanner77's Avatar
vanner77
so go with krc performances cams? but where can i find a good intake manifold? and but do you mean by h/o?
Old Sep 12, 2008 | 11:35 AM
hydrashocker's Avatar
hydrashocker
The "Y" pipe is where the exhaust pipes from each manifold come together by the oil pan. If you just keep the original it chokes the system. You want to go bigger so no choke. Magnaflow makes one.
But like they say, port and polish the heads to increase air and fuel flow into the cylinder.
BTW<-------A 68.5mm TB should be good.
Old Sep 12, 2008 | 04:32 PM
wink2873's Avatar
wink2873
by h/o he means a manifold and cams out of a high output 4.7. some of them were made with a different intake and a more aggressive cam. however 212 cams from krc are probably alot more aggressive than a factory pair of H/O cams.
