Need more mods!!
Old Sep 17, 2008 | 12:48 PM
  #31
vanner77's Avatar
vanner77
autozone... do they have them in canada? more importantly in winnipeg?
Old Sep 17, 2008 | 11:02 PM
  #32
00DakR/T's Avatar
00DakR/T
Back to the exhaust question, I did find a company that makes true duals for my truck at least, I'm not for sure if they make one for a 4.7 or not, but Spintech does. Its just high
Old Sep 18, 2008 | 01:52 AM
  #33
vanner77's Avatar
vanner77
thanks man. but im just gonna keep this exhaust for now.
so i used the sticky thread and ran the code. mine is P0441.
P0441 (M) Evap Purge Flow Monitor Insufficient or excessive vapor flow detected during evaporative emission system operation.
could anyone help me out and explain how to fix this and what parts i need. the sooner the better i get nervous when my truck has the CEL on. thanks
Old Sep 18, 2008 | 12:53 PM
  #34
varsis's Avatar
varsis
don't think there is autozone in canada but try Parts Source....
Old Sep 18, 2008 | 02:26 PM
  #35
frogmelester's Avatar
frogmelester
It means the purge solenoid in not working, or the vacuum to it is missing, a quick explanation is. After the leak detection pump passes all its tests, the PCM closes the vent valve and turn the purge on to see if it will create a vacuum in the tank , it has already check for leaks using the pump , now with the purge on and no leaks it should see the pressure switch go from closed to open . If not then it assumes there was no purge flow , hope this helps
Old Sep 18, 2008 | 10:28 PM
  #36
vanner77's Avatar
vanner77
thanks. helps a bit. if you could tell me where it is and how to fix it that would be awesome. and do i need to pick up any parts? i also heard this can be caused by over filling your tank. which i do.
