Spark plugs
Old Feb 3, 2005 | 11:58 AM
jerp's Avatar
jerp
Default Spark plugs
I replaced my original stock plugs with platinum several thousand miles ago. Well It is time to do it again. What are the best plugs to use, any recomendations?
1997 Dakota sport
2 WD
3.9L
Old Feb 4, 2005 | 11:44 AM
02dakota's Avatar
02dakota
Default RE: Spark plugs
Honestly...stock CHAMPION plugs. That is what the engine was designed with. Later...
Old Feb 12, 2005 | 01:55 AM
trucker 41's Avatar
trucker 41
Actually, I have to agree with 02 dakota. Stock is the way to go.
Old Feb 12, 2005 | 06:09 PM
BlueDak's Avatar
BlueDak
I have heard some people say that the Iridium plugs are good, but they are also $8.00 to $10.00 each. I have been using Champion Truck plugs
Old Feb 15, 2005 | 02:52 PM
steve05ram360's Avatar
steve05ram360
I disagree.. some work better than others for some reason... I had autolite 3923's in my truck and they lasted about 1000 miles before it developed a miss. It was recommended that I try these NGK ZR5F-11 plugs and it should cure the miss... well it's been over a 1000 miles already and its still runing awesome...
I recommend them.
Old Feb 16, 2005 | 03:24 PM
02dakota's Avatar
02dakota
If you must go with aftermarket plugs, follow steve00ram360's advice and buy NGK's. They are the only a/m plug I would recommend. Still, the truck was designed with Champion's, the computer knows exactly how "they" work. Install autolite's ONLY if you want your truck to misfire. They suck...
Old Feb 19, 2005 | 02:47 AM
Dodge  Dude's Avatar
Dodge Dude
ORIGINAL: 02dakota
I think I just learned this the hard way myself, thought I would try something new for once and got burned!
I put Autolite platinum 3924's in my Ram, now misfires after 1500 miles, I guess I'll go back to Champions
