1998 Dakota Wiring help
Old 10-16-2008, 08:07 PM
rhutson's Avatar
rhutson
rhutson is offline
Default 1998 Dakota Wiring help
I need to hook up a relay that only has power when the truck is running. Anyone help finding a specific connection point? I found the fuel pump relay but can't find the wire to it, I also thought about the driving lights but not sure where the wire is. Any help would be greatly appreciated.
rhutson in NC
Old 10-16-2008, 10:54 PM
00DakR/T's Avatar
00DakR/T
00DakR/T is offline
I'd say run to a parts store and spend a few bucks to get a test light. Works wonders
Old 10-16-2008, 11:49 PM
rtdakota2001's Avatar
rtdakota2001
rtdakota2001 is offline
x2.........
Old 10-17-2008, 07:35 PM
01SilverCC's Avatar
01SilverCC
01SilverCC is offline
What do you need this relay to do?
Jimmy
Old 10-18-2008, 05:28 AM
varsis's Avatar
varsis
varsis is offline
I think as long as the wire is grounded on the black connector in the power box it will only work when the key is turned forward. But not a 100% on this. Give it a shot.
Chris
Old 10-18-2008, 07:52 AM
rhutson's Avatar
rhutson
rhutson is offline
Default I figured it out
Thanks for the help, I used the test light and bought a mini add a circuit at Advance Auto Parts and added it to the O2 sensor fuse under the hood so now my accessory only has power when the truck is running. I built a Hydrogen Generator to increase my mileage, If I get good results I'll let you know.
rhutson
Old 10-18-2008, 09:59 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
i tried it already and post a DIY on it
its good on the highway but alone its useless around town the rpms run too high for any real improvement + the o2 sensor compensates for the xta o2 w/ more gas
sorry to rain on your parade
Old 10-18-2008, 12:28 PM
varsis's Avatar
varsis
varsis is offline
If you were to add a resistor somewhere on the o2 im sure you could change the sensors by a certain percent. causing it to run with your HOH gas...
Quick Reply: 1998 Dakota Wiring help
