engine swap 3.7 to 4.7
Old Nov 8, 2008 | 06:30 AM
808dakota's Avatar
808dakota
Question engine swap 3.7 to 4.7
wanted info on what would i need and does it interchange?
Old Nov 8, 2008 | 11:57 AM
varsis's Avatar
varsis
I would assume it's interchangeable. Not sure about the mounts. More than likely bolts up to the tranny and all you would need is a new computer. I hope someone else can chime in. I don't know a 4.7 so I can't look for you.
Old Nov 8, 2008 | 05:30 PM
kleraudio's Avatar
kleraudio
Man that would be sweet to be able to just drop in a v8, but I would imagine you'd need a better transmission??
Am I wrong here? And if I am, where can I get a decent v8 that I can drop in? :-)
Good question man.
Jim
Old Nov 8, 2008 | 07:14 PM
f0x672's Avatar
f0x672
as long as it's the 45rfe behind the 3.7, then you'll be fine for the 4.7.
Old Nov 9, 2008 | 06:26 PM
808dakota's Avatar
808dakota
thank you for the info.i appreciate your replys
Old Nov 10, 2008 | 12:00 PM
thumperk15's Avatar
thumperk15
I'm not sure what parts you need, but I'm sure motor mounts, and tranny mounts would be the first. I'm not sure on the tranny thats in your truck. I have a 2001 Dakota with a 408, and it had a 4.7, I shattered 3 pistons, and snapped 4 rods...lol. You would need the harness, and computer. I'd make sure you buy a complete 4.7 from oil pan, to intake, harness, and computer, and tranny, if its different, everything else should be easy, going to carbed is harder.
Old Nov 10, 2008 | 05:05 PM
f0x672's Avatar
f0x672
he cant carb the engine since neither the 3.7 or 4.7 have the ability to be carbed at all at all. and since it's the the 3.7 and 4.7 are the same engine family, he may get away with the same transmission. im pretty sure its the 45rfe behind it, which is the same one behind the 4.7.
Old Nov 10, 2008 | 06:44 PM
thumperk15's Avatar
thumperk15
I know this, I meant that to be 2 seperate paragraphs. I was talking about the swap being easy. I said that the swap from computer to carbed, is harder.
Old Nov 22, 2008 | 10:56 PM
LoveMyITGuy's Avatar
LoveMyITGuy
Good question man.
Jim
I happen to have a 4.7 engine from a 97 Dakota that will soon be parted out with
Old Nov 23, 2008 | 01:40 AM
f0x672's Avatar
f0x672
umm last i checked the 4.7 wasnt even in production and didnt even see a dakota engine bay until 2000. good try though. especially with the smiley face, almost fooled me for a second.
