99 Dakota Won't Start
Old Nov 10, 2008 | 10:38 AM
autopilot's Avatar
autopilot
Default 99 Dakota Won't Start
Help!!
I have a 1999 Dakota with a 3.9, automatic and 2wd. I cleaned the battery terminals and now it won't start.
Battery and connections to battery are fine, cracks good.
Plugs are getting spark.
Fuel pump runs for a few seconds when ignition is turned to the RUN position.
Fuel pressure at test port on fuel rail is about 48PSI.
I thought it might be flooded, all plugs have been replaced.
What do I check next?
JP
Old Nov 10, 2008 | 02:25 PM
99dakota318's Avatar
99dakota318
Does it try to turn over at all? Does it make a "clicking" noise when you try to start it? Also did it work fine before you cleaned the terminals? And are any of the battery cables corroded?
Old Nov 10, 2008 | 02:41 PM
autopilot's Avatar
autopilot
99dakota318
Thanks for the reply.
It does sound like it is trying to start about every 8 revs. I don't here any clicking noise while it is cranking. It was working fine, but with winter coming I thought I would do a little preventive maintainence by cleaning the terminals. They were not excessively corroded, I have seen a lot worse.
JP
Old Nov 10, 2008 | 05:08 PM
f0x672's Avatar
f0x672
do yourself a favor and wash the entire battery, with water and baking soda. that will clean off nearly all corrosion. let it dry off then put it on a trickle charge.
Old Nov 11, 2008 | 11:22 AM
autopilot's Avatar
autopilot
UPDATE
Rechecked fuel pressure today. Tightened gauge on port. Fuel pressure is close to 70 psi when cranking.
Does this mean regulator is bad and possible forcing fuel through injectors, flodding engine? Or is a higher then specified (44-55psi?) OK.
I am assuming regulator is part of the pump assembly.
JP
f0x672-Thanks for the battery tip. Will do that while waiting for a reply.
Old Nov 11, 2008 | 04:33 PM
lamchop's Avatar
lamchop
did you check to see if you have spark?
Old Nov 11, 2008 | 09:18 PM
varsis's Avatar
varsis
sounds like you have enough to crank the engine, but not evenough to keep up with spark and cranking. I would double check your connections. Sounds like they may not be on properly. Just check it out.
Old Nov 11, 2008 | 10:15 PM
00DakR/T's Avatar
00DakR/T
If the battery and terminals are ok, my next best bet would be distributor pickup. If that is bad, you won't have any spark.
Old Nov 12, 2008 | 03:44 PM
autopilot's Avatar
autopilot
UPDATE II
Towed to the shop yesterday. Diagnosed a bad pump. Pressure spiking to over 100 PSI. Pump assembly replaced, runs like a top ($900 dollars later).
JP
