Which bearing is bad now??
Old Nov 11, 2008 | 09:28 AM
Rezolution's Avatar
Rezolution
Default Which bearing is bad now??
It's time to play the "guess which bearing went bad now"...
My truck started making a whining/humming noise at about 170,000. It only makes the noise when my foot if off of the gas. Any time I touch the gas pedal (enough to keep a steady speed or to accelerate) the noise goes away. If i take my foot off of the gas, about a second later, it starts making noise again. I took it to the dealer to have the universals checked and they said that they are all fine. It's probably not a front wheel hub assembly because it's dependent on whether or not I have my foot on the gas pedal.
Any ideas?
Old Nov 11, 2008 | 09:41 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Give us some info about the truck , like engine, trans..., etc
Old Nov 11, 2008 | 09:55 AM
Rezolution's Avatar
Rezolution
2000 Dodge Dakota Club Cab w/ 4.7 Liter Engine, Full Time 4WD
Old Nov 11, 2008 | 10:26 PM
00DakR/T's Avatar
00DakR/T
Assuming it does it in all gears, that kind of noise (only on accel.) is typically associated with pinion bearings or carrier bearings, and probably in the rear diff. When you put your foot on the gas, you load the diff and if one of the bearings is worn, it can whine. The same thing cn also happen if the diff fluid level has been low for a long time, causing abnormal gear wear.
Anyway, thats my .02
Old Nov 12, 2008 | 08:34 AM
Rezolution's Avatar
Rezolution
Well, it wines when i take my foot off of the gas. It never makes a noise when my foot is on the gas. Does that narrow it down to which bearing it is?
Old Nov 12, 2008 | 10:48 AM
varsis's Avatar
varsis
does it do the noise while driving or does it still do it in park? ect... Im not there to hear the noise, for all you know it's some drive accessory that is shot.
Old Nov 12, 2008 | 11:21 AM
lghtngblt02
Is it a manual trans or an auto?
Old Nov 12, 2008 | 11:22 AM
Rezolution's Avatar
Rezolution
only while driving
Old Nov 12, 2008 | 12:23 PM
varsis's Avatar
varsis
Originally Posted by Rezolution
only while driving
place it in neutral and see if the noise is still there. If there is no noise it is your rear end unless you got AWD than it could be like suggested some slop in the pinion/ring gear bearings. (Give the engine a little tap on the rev.)
Old Nov 12, 2008 | 01:51 PM
00DakR/T's Avatar
00DakR/T
Just like having your foot on the gas, deceleration loads the diff bearings in the opposite direction. It still isn't really possible to determine which bearing, but you might want to remove the diff cover and see if you have alot of metal shavings in the bottom. Or thats what I would do anyway.
