P1740 ????
Old Nov 30, 2008 | 11:19 AM
HK_JJ's Avatar
HK_JJ
Default P1740 ????
im getting this error code on my truck my repair manual doesnt define this code, abody here know what this code is? thanks guys
Old Nov 30, 2008 | 11:43 AM
HK_JJ's Avatar
HK_JJ
P1740 A rationality error has been detected in either the TCC soleniod or overdrive solenoid systems.
nvm found it. any ideas whats wrong here?
Old Dec 2, 2008 | 11:05 AM
drsells's Avatar
drsells
I have the same code --- also, I am getting engine surges. Not all the time---just at steady speeds when I slightly increase the throttle.
Are you getting this too?
I think it is the TCC Solendoid and not the O/D solendoid as the surges still occur even when I turn off O/D
Anyone else have any comments about this??
Also, I did replace the TPS already.
Old Dec 5, 2008 | 09:14 PM
HK_JJ's Avatar
HK_JJ
im not getting any surges, i did notice tho that the truck sometimes shifts gears late. anyone have any thoughts?
Old Dec 6, 2008 | 11:04 PM
master tech's Avatar
master tech
Site Moderator & Tech
When you get this code, you'll need to do a torque converter stall test with a drb3 scanner. this tell you if its a pass or fail. If the test pass, then you may need to do an updated plate or spoole valve on the valve body. if it fails then front pump, torque converter and seal kit for the input shaft.
Old Dec 8, 2008 | 09:08 PM
HK_JJ's Avatar
HK_JJ
i read this on another site....
The code is thrown because the computer detects a difference in engine speed as compared to vehicle speed which logically leads to a slipping torque converter.
anyone think that i may be getting the code due to my speed sensor not working as mentioned on my other post???? i gotta get the thing fixed either way.
