98 Sport 5.2, Auto trans swap?? or stay auto....
![Exclamation](https://dodgeforum.com/forum/images/icons/icon4.gif)
I have a 1998 Dakota Sport with a 5.2, Auto. I just bought it 5 days ago and now the transmission is gone. It just barely moves in reverse and will not shift out of first gear. I love the truck and want to get it going again ASAP.
I have a friend who has a 1995 Dakota 5.2, 5sp that I can get REAL cheap as the motor is shot. What I want to know is does this truck have everything I would need for a trans swap??? Or are the clutch/brake pedal assembly, slave cylinder/clutch master cyl set up, crossmember, mounts, and so on different.
Or am I just better off getting another auto from the junkyard(though after reading all these posts and based on my own experiences im not sure I want another auto.
Any help and info would be appreciated.
Thanks
Thanks
No way. Our auto's in these trucks are strong as hell, basically 727's and 904's with an overdrive tacked on. Just as anything else goes, regular maintenance makes them last for a very long time. Neglect it and/or use crappy fluid, and you will reap the benefits. Before you buy something used, like mine with 100k on it, you have to know what you are looking at. Ha, after nine of them, I think I do...
Anyway, back to the original post, if you buy that whole truck you should be able to swap the whole drivetrain. The crossmember and mounts should be the same. maybe give it a look first before you buy it just to make sure.
the 5spd would be a good way to go. the autos just dont last.i could be wrong but isnt a 95 a different gen then a 98? if dodge didnt change anything with the motor and trans between those years then its worth a shot. it would be easy to just do a stock trans swap but it would be worth the extra time spent on it to put a 5spd in it instead!
Trending Topics
Yes, they are the same trans as the 727 and 904 by design. The internal parts are not weaker or inferior to the non overdrives. The problem on the overdrives is the torque converter. They have inferior lockup clutch material, and if not maintained, will burn up and send the junk from the converter and clutches into the valve body, which causes the rest of the trans to go haywire. That problem is DIRECTLY RELATED to improper fluid and lack of maintenance. Ask any Mopar mechanic, I guarantee you will get the same answer.
As for the question of manual or auto, it is really up to you whether you want to row your own boat or not. As far as I know, all you really need for that kind of swap is the trans, crossmember, linkage, and a pedal setup out of a second gen. IDK, first gen might work, but I am not sure, so I wont recommend. I am sure someone here has more info.
BTW, glad to be here. Nice meeting you guys.
