turn signal issue & quick tire pressure question
Old Dec 6, 2008 | 03:53 AM
MuirR27's Avatar
MuirR27
Default turn signal issue & quick tire pressure question
Ok, first things first:
I have a 2000 Dakota 4.7 4x4 and both turn signals work... for a while. Then they will stay on solid. Give it some time they work for a little longer. I have no idea what would cause this, anyone have any thoughts.
Also I've got 33's... what pressure(s) do you guys run?
Any help is greatly appreciated.
Old Dec 6, 2008 | 06:20 AM
varsis's Avatar
varsis
35 ish range on the pressure for m/t's but it all depends on where your driving... This is for road...
blinkers i don't got a clue... maybe water in your bulbs? who knows cuz that sounds weird.
Old Dec 6, 2008 | 10:14 PM
RoaminGnome's Avatar
RoaminGnome
Ya id run 35- 38psi. Id check your bulbs and connectors then go from there.
Old Dec 6, 2008 | 11:06 PM
master tech's Avatar
master tech
Site Moderator & Tech
Replace the combo flasher under the dash.
Old Dec 7, 2008 | 04:55 AM
MuirR27's Avatar
MuirR27
I know the bulbs are good. I will check the connections when I get a chance. Thanks for the speedy replies.
Old Dec 7, 2008 | 09:43 PM
TheePlaymaker's Avatar
TheePlaymaker
connections and grounds make sure their all good and i run my 31's at 40 in the back and 42 in the front cold...its gotten me 20 hw with cold weather start ups and winter gas probably better in the summer
Old Dec 7, 2008 | 09:54 PM
rtdakota2001's Avatar
rtdakota2001
its the flasher. just did one on a buick with the same symptoms.......
Old Dec 8, 2008 | 06:31 PM
big.bryant's Avatar
big.bryant
is your turn signal fluid up to the right level? lol j/k
Old Dec 12, 2008 | 10:04 PM
MuirR27's Avatar
MuirR27
thanks guys I appreciate the responses.
Old Dec 12, 2008 | 10:20 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
DAMN YOU beat me to it i was gonna say to make sure you had enough (fresh, clean) blinker fuild, and then suggest full synthetic
but yea basically what everyone else said start w/ connections, check them all, then go to the actual blinker control unit (i think its under the dashboard) and the switch in the column
