Power steering leak...cheap remedy?
Old Dec 7, 2008 | 02:03 PM
c_brown92's Avatar
c_brown92
Default Power steering leak...cheap remedy?
helllo all,
My power steering fluid leaked out entirely the other day in a matter of 4-6 hours. Is this something a "stop leak" bottle will fix or is it to fast of a leak. Also how long do i have running w/o fluid till the pump goes out?
thanks
cody
Old Dec 7, 2008 | 02:31 PM
batman13's Avatar
batman13
you gotta find and fix that leak, wont be long before your pump goes out
Old Dec 7, 2008 | 03:52 PM
f0x672's Avatar
f0x672
mine leaks a bit at the line connections at the power steering rack. find your leak, flush the system and put mopar atf4 into the system. supposedly it's supposed to help the system run cooler or w.e chrysler said. they're a bunch of crazy bastards anyway.
Old Dec 8, 2008 | 04:00 PM
c_brown92's Avatar
c_brown92
well i know it needs to be fixed...but is it gonna blow if i drive it 10 miles to get it fixed? and what i really need to know is weather the stop leak has god like qualities or not?
thanks again
Old Dec 8, 2008 | 04:08 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Do not use the stop leak!
Old Dec 8, 2008 | 04:09 PM
wink2873's Avatar
wink2873
stop leak wont fix that, but you'd probably be ok driving it 10 miles to get it fixed.
Old Dec 8, 2008 | 04:11 PM
kd7188's Avatar
kd7188
find the leak and cut the hose were it is then put a peice of hose in between clamp it and your good to go
