Cam Position sensor help!!!
Old Jan 6, 2009 | 01:49 PM
dakota00v6's Avatar
dakota00v6
Red face Cam Position sensor help!!!
hey guys imgetting the p0340 code for the cam position sensor. The problem im having is the location of the sensor, some say its under the dizzy but on the autozone websire i can only find the pick up coil, is the same thing as the cam sensor just called a diffrent name, thanks guys
Old Jan 6, 2009 | 02:08 PM
dodgerules86's Avatar
dodgerules86
The cam position sensor is located under the distributor, and goes by any name some random person whats to call it.
It's circular and flat.
Old Jan 7, 2009 | 04:28 PM
MTN13's Avatar
MTN13
From: Hometown= Highland Michigan School= Lima Ohio
it also depends on what engine you have, the 4.7 has it under the passenger side head i think, if i remember correctly, its been a while since i changed mine but the 5.2 and 5.9s are in the distributor
Old Jan 7, 2009 | 06:40 PM
zman17's Avatar
zman17
Retired Moderator - RIP
And since there is no info in your sig about your ride , other than a guess from your name , it is kind of hard to help you out.
Old Jan 8, 2009 | 08:54 PM
pumpkinheaver's Avatar
pumpkinheaver
By your sign in name I'm gonna assume you have a 3.9l engine. If so the pick up coil(some call it a can sensor) is directly under the distributor cap. It's round and flat with a wire harness hanging off it. Very easy change.
Old Jan 18, 2009 | 08:47 PM
dakota00v6's Avatar
dakota00v6
he guys thanks for all the info so far.
The trucks a 3.9l v6 100% stock. ok so the cam sensor is under the dizzy cap, do i have to pull the dizzy to get to it?
Old Jan 18, 2009 | 09:12 PM
dodgerules86
All you have to do is take the distributor cap off. You may have to disconnect some spark plug wires (please, for your sake, make sure you label them before you take them off, otherwise it will cause all kinds of driveability problems)
It's really easy.
Old Jan 19, 2009 | 07:33 PM
dakota00v6's Avatar
dakota00v6
cool so no reseting the timing. thanks for the info, ill get back with my experience, wish me luck lol
