lift blocks
Old Feb 13, 2009 | 02:40 PM
varsis's Avatar
varsis
Originally Posted by dualdakota01
*** hey Magnethead... i missed your post up there. good idea tho.. maybe i should actually just go with the shackles. seems alot better and safer. i looked on 4wheelparts.com but do u guys have any hints on what shackles u've used or i should get? again im look'n for 1-2" lift for the back. Depending on how much i have for front once the tb crank is done.
longer shackles on a 4wd will lower it. you need to flip it first than you can get longer shackles.
Old Feb 13, 2009 | 08:43 PM
dualdakota01's Avatar
dualdakota01
right.. sorry i mean like what magnethead was saying with the leaf brackets? anyone lifted with those instead on back?
Old Feb 13, 2009 | 08:55 PM
varsis's Avatar
varsis
a shackle flip. A easy way to get some lift is to get some front brackets off a donor vehicle and put them in the back in place of the stock ones. Ideally you will weld them on.
