probably been asked before, but i can't find it
My math above (for being from thin air, came out awfully close) said 3.22. nearest is OEM is 3.21.
Its all stock minus the air filter. I did the math, a little differently (by taking my tire specs off the net: 751.1 rotations per mile and back calculated by using my already identified 3.21 ratio.) And the preliminary winner is the AX15, however I will repreform this "test" when not driving in a city trying to watch RPM and MPH and the ROAD. I will also do it using a camera so I can just take a picture and figure out the nitty gritties after I have parked . After I take pictures, I will cross check my prelim #s with 4th gear, as it is listed for every tans in question as being the 1:1 ratio.
So, not to beat a dying horse, but to get back to the second part of my original question. Is there an easy way to identify these three from each other by looking at them, ID tags, stampings, casting styles, bolt placement...? (because it sounds like all are possibilities for different Dak's) I am more than happy to crawl under most any truck to get the low down on what it can do. To drive this home again, I am looking at getting a newer Dakota (04) and would rather look under it than trust a seller to know their trucks. Im far from an expert, but try hard not to be ignorant about what I have and how it should/does preform.
Thanks for all the posts thus far, and let me know if I am going overboard with this~just trying to be thorough.
goat
goat
im still not understanding the point of all this. no matter what you do the trans from an 04 is going to be different, and aside from being able to embarass the guy you're buying the new truck from I dont really see the point.
if you just want to know what is in the 04, get the vin and have a dealer run you a build sheet. it will tell you everything thats on the truck from the factory.
http://rds.yahoo.com/_ylt=A0WTb_1GMZ...s.org/ax15.jpg
if you can tell the difference, this one is supposed to be an ax15
http://i12.ebayimg.com/04/i/07/b0/7e/cb_3.JPG
and this one is supposed to be an nv1500
maybe you can find something thats unique to one of them and decide when one you have. i didnt really look at them too hard.
