on board air time :D
Old Feb 18, 2009 | 08:29 PM
batman13's Avatar
batman13
Default on board air time :D
alrighty, tomorrow im heading over my buddys shop,
i have 2 5 gallon air tanks, 2 viair 480 electric air compressors and an engine driven sanden 709 air compressor, all are going to be installed and running by the end of the day tomorrow,
fill times from 0 to 200 psi will be right around 2.5 minutes, at idle
tanks and 480s
the engine driven (its the part that looks like an a/c compressor)
and the gauge i will be using to monitor tank pressures from my drivers seat
and the new location for the gauge
Old Feb 18, 2009 | 08:43 PM
wink2873's Avatar
wink2873
thats good but do you already have the truck bagged or whatever you guys call it?
Old Feb 19, 2009 | 02:34 PM
batman13's Avatar
batman13
no i dont, this is step one,
Old Feb 19, 2009 | 02:49 PM
matj1990's Avatar
matj1990
dont u normaly bag then air it ?
Old Feb 19, 2009 | 02:54 PM
batman13's Avatar
batman13
you need air first to run air ride.
if it were an air load leveling system i wouldnt need the on board air
Old Feb 19, 2009 | 02:58 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
bat, why do you have an engine driven compressor and the electric ones in the bed???? wouldnt just one set be sufficient??
Frenchy's Avatar
Frenchy
batty, you need to fix your sig...
the silhouette of the truck shows the frame riding, and the wheels off the ground...
Sheesh, and you call yourself a decent photoshopper...
Old Feb 19, 2009 | 03:15 PM
f0x672's Avatar
f0x672
haha yeah batty we can fit a pus*y hair underneath those wheels in that sig, haha. but about time we start seeing this thing on bags already
Old Feb 20, 2009 | 12:57 AM
batman13's Avatar
batman13
because, the more you have, the faster your tanks fill, thats the whole idea
got the system plumbed, and the comps and tanks mounted and the engine driven all hooked up,only took 8 hours lol
so far holds pressure, absolutely no leaks, didnt get a chance to wire anything, but thats all is needed at this point,
Old Feb 20, 2009 | 03:15 PM
batman13's Avatar
batman13
tank 1, has a quick connect on top, and the pressure sender (gauge) and pressure switch(on/off)
tank 2, has a gauge on top, and a water trap from the engine driven compressor
and my super baller digital gauge
