finally gotta get it done.....
Old Feb 22, 2009 | 06:20 PM
HK_JJ's Avatar
HK_JJ
Default finally gotta get it done.....
well im back to that spedo problem i had a while back , never fixed it cause i havent really drove the truck all winter, its get no grip in the snow.
now apparently iv got 3 speed sensors, one on the diff and one at each front wheel. is there anyway to test these? they are like $50 a pop, so id rather not change something that isnt broken. everything else works on my cluster but the spedo and km. also my cruise doesnt set, i set it and it slows to 0km.
my haynes manual doesnt go into detal on the sensors so im at a loss.
Old Feb 22, 2009 | 06:58 PM
varsis's Avatar
varsis
id try the rear one first. I think there is one in the transmission id try that too.
Old Feb 22, 2009 | 07:18 PM
HK_JJ's Avatar
HK_JJ
i not sure if there is one on the tranny, i was juss told of the other 3. looks like i may juss have to start replacing the sensors one by one.
Old Feb 22, 2009 | 10:08 PM
RoaminGnome's Avatar
RoaminGnome
If they are the same sensor you can replace one and if it doesnt fix it swap it to a different spot. Just a thought
Old Feb 23, 2009 | 06:26 PM
big.bryant's Avatar
big.bryant
"but officer my speedometer said i wasn't speeding"
yeah i wouldn't use that one but it MIGHT work
also your mileage won't be going up at all lol
Old Feb 23, 2009 | 07:45 PM
RoaminGnome
lol ya admitting fault is not a good idea at all! Youll pay for that kind of comment
Old Feb 23, 2009 | 10:34 PM
JBs DAK's Avatar
JBs DAK
Do the rear/end speed-sensor 1st. It's about 23 bucks at Auto-Zone.
It's on the top of the rear/end.
Then, try the one on the pass-side of the trans,.. It's the same price,..
23 bucks. No idea about the third one but, It could be the plug on the
back of the gauge cluster. It's a real cruddy design the way it mounts
to the dash-frame. It becomes loose over time.
Old Feb 24, 2009 | 09:59 AM
HK_JJ's Avatar
HK_JJ
lol that may work for a few of the local cops here, but def. wouldnt work on the o.p.p.... ill try the rear one first and then go from there, im in ontario so i dont have an auto zone near me, the sensor is double th price up here. first tho i will check out that plug into the cluster, who knows i may get lucky.
cheers
