dakota issue
Old 03-01-2009 | 07:01 PM
bgibb68's Avatar
bgibb68
Default dakota issue
ok so i just got the motor back together from replacing the vc and intake mani gaskets. had the injectors cleaned, cleaned the gunk out of the top yada yada yada.
so it started right up and idles good and probably smoother than before.
but in park and neutral even the slightest tap on the gas pedal the rpms go up to 3k and hold for a few secs and then slowly come down. in drive or rev it runs fine.
after 3 starts the 'check gauges' light came on, no CEL.
it shows oil pressure, but i think i may have broke the coolant sensor that is to the left of the thermostat. weird thing is it shows coolant temp.
any ideas??
Brian
edit: it's the 3.9l v6 and it's a '98
Old 03-01-2009 | 07:06 PM
varsis's Avatar
varsis
vacuum leak.
Old 03-01-2009 | 07:09 PM
bgibb68's Avatar
bgibb68
Originally Posted by varsis
vacuum leak.
i replaced all the lines......but with a vac leak, wouldn't the rpms drop to stall level.....not go up to 3k and hold with a tap on the gas??
that's how my car was with a vac leak...the rpms would just drop
Old 03-01-2009 | 08:34 PM
bpark8824's Avatar
bpark8824
throttle cable?
Old 03-01-2009 | 08:38 PM
magnethead's Avatar
magnethead
Originally Posted by bpark8824
throttle cable?
wouldnt think so
Old 03-01-2009 | 09:13 PM
Dakota_SuperChips's Avatar
Dakota_SuperChips
Does it have and IAC Valve(Idle Air Control Valve)?? If so you might want to try replacing it or the Throttle Position Sensor.
Old 03-01-2009 | 10:05 PM
varsis's Avatar
varsis
pull a vacuum line off and tell me it stalls. It raises your rpms to about 3k.
Old 03-01-2009 | 10:07 PM
bgibb68's Avatar
bgibb68
i was thinking the tbs and maybe dirt or dust got up in there....i'm gonna go get some elec cleaner and hit the connectors...
so what about the check gauges light?any ideas??
Old 03-01-2009 | 10:09 PM
bgibb68's Avatar
bgibb68
that why i also asked about that? vac leaks on my car(mazda 4cyl) the rpms drop and just about stalls.....
the rpms only go up with a slightest touch to the throtle and then comes down and holds steady
Old 03-01-2009 | 10:20 PM
magnethead's Avatar
magnethead
That's what i thought! cuz vacuum leak = unregulated airflow into the motor = lean condition = computer adjusts = more fuel = rev spike?
Quick Reply: dakota issue
