Whole lotta stuff...
Old Mar 9, 2009 | 09:53 PM
  #21
big.bryant's Avatar
big.bryant
yeah you are right but since money isn't an issue in the situation, might as well take advantage of it... it also gives me a reason to re-do my sig
Old Mar 9, 2009 | 10:46 PM
  #22
rtdakota2001's Avatar
rtdakota2001
https://dodgeforum.com/forum/2nd-gen...akes-done.html
Old Mar 9, 2009 | 11:13 PM
  #23
big.bryant's Avatar
big.bryant
where/what brand are those rotors?
Old Mar 9, 2009 | 11:22 PM
  #24
magnethead's Avatar
magnethead
http://store.summitracing.com/partde...0&autoview=sku
Old Mar 9, 2009 | 11:27 PM
  #25
big.bryant's Avatar
big.bryant
dayum... thats a whole lot CHEAPER than i was seeing elsewhere... thanks for the link..
Old Mar 9, 2009 | 11:30 PM
  #26
magnethead's Avatar
magnethead
chit you're right...i think that's cheaper than orielly's! too bad i already did my fronts!
remember that slotted rotors are directional!
Driver front: http://store.summitracing.com/partde...0&autoview=sku
Pass front: http://store.summitracing.com/partde...0&autoview=sku
  #27
rtdakota2001
DAMNIT! i paid 65.95
Old Mar 9, 2009 | 11:43 PM
  #28
big.bryant's Avatar
big.bryant
ya man i found those and then i found a clutch for only like $295 on summit also:
http://store.summitracing.com/partde...5&autoview=sku
Old Mar 10, 2009 | 02:13 AM
  #29
stesul411's Avatar
stesul411
For the rear discs, older V8 Grand Cherokee disks are pretty much a bolt on. You'll have to redrill the rotors to 6 bolt (the bolt circle is the same, 4 1/2") and fab up something for the parking brake. Just make sure you get all the parts from the Jeep axle and the brake proportioning valve. Jeep guys have been doing this swap for a long time.
Actually there are lots of parts that can be swapped between Jeep Cherokees / Grand Cherokees and first and second gen Dakotas. Example, rear axles, both Cherokee and Dakota used 8.25 units, and are exactly the same width flange to flange and between the spring pirches although they used different axles, and dif carriers.
Old Mar 10, 2009 | 03:35 AM
  #30
Spike300's Avatar
Spike300
[QUOTE=batman13;1580250][QUOTE=Spike300;1580242]
yes, i posted it up before you
its a viper conversion but it dosnt have the master cylinder, its just the brackets and calipers[/QUI didnt scroll down enough just hit reply:-P
