oil pan
Old Mar 11, 2009 | 02:29 PM
bgibb68's Avatar
bgibb68
ok so i have the engine raised and the underside of the mounts resting on bolts like in the steps.....but there still is not enough room....did they put bigger trans casings on some models or bigger oil pans....it's almost looking like i have to pull the trans
Old Mar 11, 2009 | 03:14 PM
magnethead's Avatar
magnethead
have you tried loosening the trans mount?
Old Mar 11, 2009 | 04:02 PM
bgibb68's Avatar
bgibb68
i gave up trying to pull the pan....i can move the pan around enough to get to the pump and gasket......
Old Mar 11, 2009 | 04:22 PM
bgibb68's Avatar
bgibb68
well here are pics of the pan with the motor as far up as it will go
File Type: jpg
File Type: jpg
Old Mar 11, 2009 | 04:27 PM
batman13's Avatar
batman13
you didnt try unbolting the motor did you? that would probly give you a little more wiggle room
Old Mar 11, 2009 | 04:32 PM
bgibb68's Avatar
bgibb68
unbolting the motor...as in the mounts....yeah the motor is sitting on top of the the mount(i have the bolt on the frame side and the engine side mount is sitting on the bolt) and the tranny mount is unbolted..
if i raise more i would run the risk of breaking lines from the trans...the lines are directly on the undercarriage
Old Mar 11, 2009 | 04:36 PM
batman13's Avatar
batman13
ah... i skimmed the thread,
Old Mar 11, 2009 | 05:28 PM
bgibb68's Avatar
bgibb68
it's the tranny inspection cover.....
at first i didn't know what it was or anything.....i thought they were talking about the oil pan for the tranny.....
AH HA
Old Mar 11, 2009 | 06:44 PM
bgibb68's Avatar
bgibb68
so i've gotten the starter off to pull the dust cover......but it won't "slide" out
Old Mar 11, 2009 | 07:20 PM
magnethead's Avatar
magnethead
from having worked on both a 305 SBC and a 454 BBC, the starter should just drop down (make sure your batt is unhooked for safety reasons) then the dust cover drops as well.
