driving lights
Old Mar 11, 2009 | 01:51 AM
stewartj1998's Avatar
stewartj1998
Default driving lights
i have a 97 dakota sport, when i bought it the driving lights wouldnot come on, replaced the switch and still nothing, checked fuse (in dash) it was fine, looked under hood and the fuse block for driving lights was gone, replaced it and lights came on , but they stay on all the time, truck running or not, lights on or off, have to pull out fuse block to shut them off! any suggestions? (green light on driving light switch doesnt come on either) thanks
Old Mar 11, 2009 | 01:59 AM
magnethead's Avatar
magnethead
I'm assuming you're talking about the Fog's (which legally aren't to be used as driving lights, but f*** that law). My first guess would be an internally shorted (or manually by-passed) switch, second would be an improper re-wire hackjob.
Old Mar 11, 2009 | 02:05 AM
CSCustomCars's Avatar
CSCustomCars
you know that's funny. When I bought my Dak, the fog light relay was missing as well. Although I don't have the same problem as you do.
Did you buy a brand new Relay or did you use an old one? You may have a bad relay. Or like magnethead said, something is supplying power at all times through the relay by-passing the switch. You said you replaced the switch. It Could be faulty. Try putting the old one back in.
Old Mar 12, 2009 | 01:17 AM
stewartj1998
yeah fog lights, im leaning toward the hack job
Old Mar 12, 2009 | 01:20 AM
stewartj1998
yes new relay, new switch also, did not try putting the old one back in, will try that,
