Heavy clutch?
Old Mar 29, 2009 | 10:02 PM
primus454's Avatar
primus454
Default Heavy clutch and loud shifter/tranny
Question 1:
So, I just got my Dak and it's great. But the clutch takes quite a bit of effort to push down. Is there anything I can do to make it easier at all or anything I should check? I'm sure it wont be a problem in a few weeks after I build up my leg, it would just be nice to avoid the sore leg in the mean time.
BTW, I am aware that the system can't be bled.
Question 2:
Okay, so this truck just had the tranny replaced (not by us) and it seems that when the shifter was put back in place, they left out sound deadeners which means that the cab is basically filled with noise from the tranny. So does anyone know about sound deadeners in the shifter and replacing them or whatnot?
Old Mar 30, 2009 | 12:41 PM
TheePlaymaker's Avatar
TheePlaymaker
i think thats just the way they are...do you know what kind of clutch they put in it cuz that could make it stiffer if its an after market one but mine is pretty stiff too just gotta get used to it...there is sound deadening in the tranny well under the truck but it doesn't do that good of a job...i have the hurst shifter and just that being all metal compared to stock has made it really loud inside...if you take off the floor console you could probably put some dyno mat or something down to quiet it down a little.
Old Mar 30, 2009 | 05:49 PM
big.bryant's Avatar
big.bryant
ya the stock clutches are decently rough, my stage 2 is worse but i am just used to it by now... also these are really noisy transmissions so i would just say turn up the stereo and deal with it (its what i do...)
Old Mar 30, 2009 | 08:05 PM
primus454's Avatar
primus454
No radio in it . Oh well. It doesn't sound too bad now that I've driven it a little. I don't really need a radio too terribly.
And on the clutch, now my joints are fine, but it's the muscle thats sore . But at least the muscle will build up, as the joints only wear down.
Old Mar 30, 2009 | 08:07 PM
big.bryant's Avatar
big.bryant
That'a boy!
Old Mar 30, 2009 | 09:22 PM
cramerica's Avatar
cramerica
Once in a while I get in my company car and without paying attention give the floorboard a good mule-kick, expecting a truck clutch there...good times.
Old Mar 30, 2009 | 09:39 PM
95_318SLT's Avatar
95_318SLT
Thats not exactly true. It is not designed to be bleedable, but you can bleed it. I did an auto to manual swap in my truck, and I took apart the hydraulic system and dumped out all the old fluid before I realized there was no bleeder valve. Here is what I did to bleed it...
Remove the slave cyl from the transmission with the line still attached to it but remove the line from the master cyl. Get a short peice of rubber hose that will fit snug over the line, attach it to the master cyl end of the line and hold the assembly so that the slave cyl is the lowest point and the top of the line is the highest point, and take the attached hose and stick it in a bottle of brake fluid. Pump the slave cylinder until you no longer see air bubbles coming out of the hose. Fill up the resevoir so that fluid drains out of the master cyl and quickly reattach the line to the master cyl. Pump the slave cyl 2 or 3 more times until you no longer see air bubbles in the resevior.
Unfortunately I did not get any pictures, so I hope this explanation makes sense. It worked great for me.
Old Jun 22, 2010 | 09:20 PM
mightyminder's Avatar
mightyminder
I thought my Dakota had a heavy clutch until I changed the clutch out. Then, for a few days, it became very light, I kept putting my foot through the floor. After about a week it became very heavy again, and I am not sure why.
Did bleeding it help?
Old Jun 23, 2010 | 01:14 AM
Independentfool's Avatar
Independentfool
this place has what i believe to be the best line of sound deadener, and its cheaper than Dynomat and other big names.
http://www.secondskinaudio.com/
