Replacement of whole exhaust system
Old Mar 30, 2009 | 11:54 PM
gavinfixit's Avatar
gavinfixit
Default Replacement of whole exhaust system
1998 Dodge Dakota SLT 4WD
The exhaust system on this vehicle is completely rustified, from the manifolds to the exhaust tip. There are two sizable breaks/cracks where the manifold connects to the y-pipe and also where the cat connects to the forward run.
My question concerns what to replace it with. I would like to go with a header kit and replace everything with ceramic or stainless.
Any suggestions out there on what to get, on a low to mid budget? With a header kit do you have to upgrade the Cat to a performance model or can you go with a standard OEM replacement?
Thanks!
Old Mar 31, 2009 | 12:09 AM
gavinfixit's Avatar
gavinfixit
BTW, the above Dakota model is a 5.2L 318-V8.
Regards
Old Mar 31, 2009 | 10:29 AM
TheePlaymaker's Avatar
TheePlaymaker
not to sure one header kits and what not but a magnaflow hi flow cat is cheaper or the same price then most oem replacements so i wouldn't see why you woudln't get one.
Old Mar 31, 2009 | 10:39 AM
jagass's Avatar
jagass
Ceramic is much better...
Old Mar 31, 2009 | 09:13 PM
big.bryant's Avatar
big.bryant
replace it with something good if you are going to replace it... screw OEM
