Steering Column Rattle
Old Apr 3, 2009 | 11:10 PM
mdknaebel's Avatar
mdknaebel
Question Steering Column Rattle
Hey I've got a 02 Dakota QuadCab 4.7L. When I hit a large enough bump (not very large, like a small pot hole, for example), I hear, and kind of feel a rattle, almost a soft banging, or knocking in the steering column area. If I'm on a bumpy dirt road, there is almost a constant knocking noise and sounds kind of bad, enough to make me slow down. Any ideas on what it could be?
Thanks!
Old Aug 20, 2009 | 04:13 PM
klings designs's Avatar
klings designs
Thanks!
Anyone.. i know there was somehting somone posted about tightening somehting under the dashboard... Mine does this all the time just wondering if someone can help me out.
Old Aug 20, 2009 | 04:37 PM
Josh Abels's Avatar
Josh Abels
could this be part of the recall that was issued on our trucks a while ago for the steering column, im not sure just throwing it in there
Old Aug 20, 2009 | 04:39 PM
klings designs
I drive an 04
Old Aug 20, 2009 | 04:54 PM
deranged's Avatar
deranged
I think that recall was for the gear selector detent. I don't really know what the problem would be other than mounting bolts or something inside the column cover. It comes off fairly easy so if the column bolts are tight I'd be looking in there. Or then again maybe it's your keyfob!
Old Aug 20, 2009 | 09:10 PM
project99's Avatar
project99
I have the same knock but havent investigated it yet. Keep me posted,
Old Aug 21, 2009 | 10:38 AM
heavyjay's Avatar
heavyjay
Here's the link to the TSB and adjustment procedure. This TSB came out in 1999, so I don't know if it addresses what is causing your issue. The book time on it is 12 minutes, so even if it takes you a half hour you have nothing to lose by trying.
http://autorepair.about.com/library/a/1g/bl669g.htm?p=1
