Tail lights with amber turn signals
Old May 11, 2009 | 03:56 AM
9000+'s Avatar
9000+
Default Tail lights with amber turn signals
Anybody know where i can get some aftermarket tail lights with proper amber turn signals for my 99 Dakota?? thanks
Old May 11, 2009 | 04:14 AM
big.bryant's Avatar
big.bryant
start by checking eBay and summitracing.com and stylintrucks.com
Other than that just google it and see what comes up.
Cheers.
Old May 11, 2009 | 04:35 AM
dodgerules86's Avatar
dodgerules86
I believe you only need amber turn signals on the front?
Back can be amber or red. As they are red on stock Dakotas.
Old May 11, 2009 | 04:47 AM
9000+'s Avatar
9000+
Yeah, the red signals arent ilegal, i just dont like them, i get annoyed whenever im driving behind someone with them, because when they are braking and signalling at the same time, and they tap the brakes, i can't tell which way they are signalling, so i don't want to be hypocritical and change mine
Old May 11, 2009 | 01:20 PM
CSCustomCars's Avatar
CSCustomCars
You are going to have to wire in new ones. Since the brake/turn filament is the same, you'll have to wire in a third bulb (One reverse, One tail/Brake, one turn). It's not going to be as easy as it seems.
Old May 11, 2009 | 05:07 PM
dodgiee's Avatar
dodgiee
Cheers.
I agree, you can always take a look in ebay for cheap price.
Old May 11, 2009 | 05:30 PM
magnethead's Avatar
magnethead
agreed. You'd have to run a new power line from under the dash to the back of the bed.
Old May 12, 2009 | 02:19 AM
bpm's Avatar
bpm
I've looked for these too,I feel the same way,don't like the red and think they should all be amber turn sig's in the rear...
I also don't like the clear lenses/colored bulb thing, very hard to see in bright daylight,
I ride a motorcycle and it really is dangerous sometimes...
I don't think I found any assemblies where they're separated,I was goin to rewire mine,but use the reverse light section of the housing for the turn sig. w/amber bulbs and relocate/add reverse lights somwhere else...
Old May 12, 2009 | 03:09 PM
batman13's Avatar
batman13
go to mexico...
mexican daks have amber turn signals stock
Old May 12, 2009 | 03:21 PM
ibcnul8r's Avatar
ibcnul8r
I personally don't think you'll have much luck. Since Dakotas are built in the USA, I don't think you'll find any AMBER/RED tail-lights for it. If you notice... when you're seeing these vehicles with amber/red tail-lights, they're probably japanese/foreign.
And don't forget. If you do have any luck, remember your flasher might be affected by your change too.
Good luck.
