Odd rear bounce when breaking
Old May 22, 2009 | 06:41 PM
markgrass's Avatar
markgrass
Default Odd rear bounce when breaking
I have a 2000 Dakota Quad Cab 4.7 4X4. 186K miles.
Lately I have notice that when breaking and decelerating between 40 and 30 MPH I am feeling an odd bounce. The bounce seems to be coming from the rear. Breaks are relatively new ( 1 year old). All 4 were done at the same time and look good. I have inspected the rear suspension but find nothing obvious. Any suggestions of what this could be????
Old May 22, 2009 | 07:45 PM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
would u say a bounce? or a thump/clunk?
maybe your rear differential is done...gears all screwed up inside. pull off the diff cover and see if there is anything obvious. hell, if u take off cover only to find no fluid bhind there, that's what led to the problem. good luck have fun
Old May 23, 2009 | 01:02 AM
User's Avatar
User
Flat spots on tires, bubble on tires, check the tires, or just pull the fill plug on the dif and stick your finger in it and see if there is fluid.
Old May 23, 2009 | 12:56 PM
markgrass's Avatar
markgrass
Definitely a bounce or even a shake up and down. No noise related to it. I check both differentials and gear oil is at the recommended levels.
Old May 23, 2009 | 02:36 PM
bpark8824's Avatar
bpark8824
All your wheels weights still on? If the tires are out of balance she will throw you around pretty good.
Old May 24, 2009 | 03:55 PM
markgrass's Avatar
markgrass
Well is appears that the rotors were warped. Replaced them and everything is riding smooth.
These were only 1 year old and pads had a lot left to them. not sure what caused this to happen.
Old May 24, 2009 | 05:38 PM
bpark8824's Avatar
bpark8824
That will do it.
