driveline fluid change... summary & pics
Old May 31, 2009 | 10:32 PM
f0x672's Avatar
f0x672
just keep a heads up, if that fluid looked like an 8 year old girl poured a bottle of glitter in it, well atleast i can tell ya thats a thrust washer that wiped out.. atleast i can say that happened to me when the toque converter dumped its thrust washer.. good times..
Old May 31, 2009 | 10:34 PM
wink2873's Avatar
wink2873
Originally Posted by CSCustomCars
Yeah man, if the snap ring completely breaks or comes out, there won't be anything holding the clutch pack in place, so when fluid pressure tried to engage the clutch pack, you won't have anything to push against, and you won't have whatever gear that pack engages.
May I ask what transmission you have? Curious if I have to look forward to the same thing...
its a 42RE. Unless you have a 4.7 *it has a different trans*, you very well could end up with the same problem. the 42/44/46 RH/RE are basically the same design.
I was thinking of maybe trying to find a cheap 42RE at a junkyard somewhere when i get the money, looking it over really well and installing a shift kit. Im not about to tear apart a transmission, I'd never be able to put it back together. That way, once my original transmission starts to screw up, i'd already have a replacement at hopefully around 1/3 the price of a full rebuild.
Old May 31, 2009 | 10:36 PM
wink2873's Avatar
wink2873
the fluid didnt look that bad... just a little brown. definately no glitter in it.
Old May 31, 2009 | 10:37 PM
bpark8824's Avatar
bpark8824
Thats the best way to go about it. I had a rebuilt one put in for $1200 which from what I have heard is low. But im sure you could get a decent one of out a totalled dak for half that.
Old May 31, 2009 | 10:38 PM
f0x672's Avatar
f0x672
you can do a rebuild yourself, with a good shop manual, and some snap ring pliers, puller, some some other various special, but easy to acquire tools. these units are cake to rebuild, just take your time. i did a rebuild on one out of a 99 grand cherokee.
Old May 31, 2009 | 10:41 PM
bpark8824's Avatar
bpark8824
^ Hes right, if you have time, patience, the right tools, and some mechanical ability, you could do it.
Old Jun 1, 2009 | 08:10 AM
CSCustomCars's Avatar
CSCustomCars
I do have a 4.7.
And yeah man, get yourself a good rebuild book, and build her up yourself.
Old Jun 1, 2009 | 09:24 AM
bpark8824's Avatar
bpark8824
Oh I thought you had a 5.2 so you have a 45 rfe, which is supposed to be a better tranny, so you shouldn't encounter the same problem but still its a Dodge transmission.
Old Jun 1, 2009 | 03:42 PM
wink2873's Avatar
wink2873
im going to be keeping an eye out for a 42RE. if i find one that isnt totally destroyed and at a good price, i'll buy it. Then i'll buy a rebuild book and a master overhaul kit, and a shift kit and hopefully i'll have plenty of time to get it all together. This will all eventually work into my plan of a 360 swap someday. I'd feel more comfortable with a built 42RE like varsis did, than i would with a stock 42RE thats already been through who knows what. I'd also like to keep a 42RE for simplicity's sake instead of trying to swap in a 360/727 combo. you'd have to deal with electrical nightmares, custom driveshaft, etc... I would also probably rebuild the rear end or at least install a stronger, limited slip diff like a truetrac at the same time.
