97 3.9l backfire?
Old Jun 10, 2009 | 08:22 PM
97dakota2wd's Avatar
97dakota2wd
Default 97 3.9l backfire?
i recently purchased a 97 dakota 2wd v6 auto. i replaced the injectors with bosch injectors and just did the intake gasket and new timing chain. it also has new cap, rotor, plugs, wires and new throttle position sensor. i cant seem to figure out why it back fires through the intake and hesitates when i am trying to take off in drive. if you rev it in neautral it doesn't seem to do it as bad but you still notice the hesitation when you give it throttle. any ideas on what it could be? thanks
Old Jun 10, 2009 | 08:23 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
well if you did the timing chain, are you sure its it perfectly in time again? im not doubting you, just asking.
Old Jun 10, 2009 | 08:31 PM
97dakota2wd
yes marks lined up on sprockets it was doing it before just had alot of timing chain rattle it was so bad it was slapping the inside of the timing cover. i thought timing was off to but it adjust itself correct?
Old Jun 10, 2009 | 08:36 PM
tamcnally's Avatar
tamcnally
was it backfiring at all before you put the new timing chain on? bc if it was, and the old one was a loose as you say it was then its possible that it skipped some teeth and got out of time before you changed it.
Old Jun 10, 2009 | 09:40 PM
97dakota2wd
yes it was doing it before but i lined the new sprockets with the timing dots on them and the crank and cam are keyed so i couldn't have installed them wrong.
Old Jun 12, 2009 | 10:32 AM
97dakota2wd
i replaced the crank position sensor it seemed to help a little. i was wondering how long it takes the computer to relearn the signal and adjust the parameters.
