Center Console DIY
Old Jul 21, 2009 | 07:04 AM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
yea i just had that 3rd seat in there.
Old Jul 22, 2009 | 04:21 AM
Loud Pedal's Avatar
Loud Pedal
The Total Package
if you had a table saw it would have been ALOT nicer...but with the tools listed....nicey done
Old Jul 22, 2009 | 04:45 PM
batman13's Avatar
batman13
just a wee bit of advice,
box looks good.. but you really should have screws in it.... a bunch of them, the vibrations of the sub will indeed break the glue bond, and i dont think it'll take too long esp with a sealed box
just a warning
Old Jul 22, 2009 | 05:01 PM
tamcnally's Avatar
tamcnally
just a warning
there is screws and nails in it. along with glue and silicone. yea i kinda figured it might blow it apart with it being sealed. there are ports in it, but probably not enough. but thanks for the advice!
Old Jul 22, 2009 | 05:05 PM
batman13's Avatar
batman13
ah.. i musta missed the screws
if its ported you can find the proper port specs and make sure its tuned right
Old Jul 22, 2009 | 05:07 PM
tamcnally's Avatar
tamcnally
where could i find something like that? all i did was put 2 3.5'' holes on the side of the box under the cb. i did that after i started using it and it sounds 10 times better than it did.
Old Jul 22, 2009 | 05:20 PM
batman13's Avatar
batman13
probly on MTX's website should list all the specs you'd need
Old Jul 25, 2009 | 11:49 AM
RoaminGnome's Avatar
RoaminGnome
Ok so hows the 10 sound in a RC? Im gonna do audio (at some point...) and im thinking a 10 would be best. What do you listen to and how many watts is it getting?
Old Jul 25, 2009 | 01:14 PM
tamcnally's Avatar
tamcnally
i listen to pretty much everything, hip hop, rap, country, classic rock, alt. rock. and it sounds awesome. it still have the stock door and rear speecks in there, so when i get around to upgrading those it will sound so much better and im only using a 300 watt amp.
Old Jul 27, 2009 | 05:52 PM
RoaminGnome
awesome! I can tell you from experiance that the rear speakers dont do much. Unplug them or change the balance/fade and try it out before you remove them
Im going to get a 3 channel amp and just do fronts and a 10", just wanted to get your input since you have a RC too
