What would I need to do...
Old Jul 28, 2009 | 02:52 AM
big.bryant's Avatar
big.bryant
Default What would I need to do...
...to my truck to be able to run this setup?
http://www.krcperformance.com/krc/in...hk=1&Itemid=26
Old Jul 28, 2009 | 09:46 AM
bondslayer's Avatar
bondslayer
Buy it and install it.. Hah. You need a wideband a/f monitor which can datalogg map voltage, rpm, and throttle position to ensure a dead on tune. When you run a high boost #, that is when bigger injectors and fuel pumps and motor internals come into play. You can run 6-9 psi all day long as long as your tube is correct!! You can pm me if you need/want more info!
Old Jul 28, 2009 | 11:59 AM
Billiam's Avatar
Billiam
Well you'll need money and the know how.. lol
Old Jul 28, 2009 | 07:23 PM
rtdakota2001's Avatar
rtdakota2001
yeah it looks pretty complete it just sucks that its a remote setup those always seem to encounter problems.
Old Jul 28, 2009 | 09:37 PM
big.bryant's Avatar
big.bryant
It says it comes with a 12psi wastegate spring... could i run that on stock internals or is that going to be pushing it?
Old Jul 29, 2009 | 12:15 PM
bondslayer's Avatar
bondslayer
A waste gate is controlled by a spring, which determines at how much pressure when it opens. It is good UP TO 12psi of boost, meaning if you run 6psi, your fine.
There isn't a lot of know how, it's pretty much a bolt on addition, minus the exhaust tubing etc. The wideband will be added into the header which is a series of wires etc, but the directions are straight forward. I will try and get some exhaust pictures for you, so you have a better idea.
Old Jul 29, 2009 | 12:18 PM
bondslayer's Avatar
bondslayer
I am trying to get some exhaust pictures now, so I can post them and it will be easier for you to understand.
Old Jul 29, 2009 | 11:57 PM
big.bryant's Avatar
big.bryant
thanks... yeah pictures will defininately help out a bit
Old Jul 30, 2009 | 01:51 PM
bondslayer's Avatar
bondslayer
Old Jul 30, 2009 | 09:54 PM
bpark8824's Avatar
bpark8824
I just don't know the purpose of turboing a QC 4wd truck...
