2001 Dakota 4.7 V8 Balljoint issues
Old Aug 19, 2009 | 07:55 AM
luisgrandich's Avatar
luisgrandich
Default 2001 Dakota 4.7 V8 Balljoint issues
Hi to all:
Could you please help me and walk me through the steps that I need to do to replace the balljoint in the driver side? My mechanical skills are in the medium level. But I want to do this.
Thank you
Old Aug 19, 2009 | 08:40 AM
zanethan's Avatar
zanethan
You either have to replace the entire upper control arm which is about $100 each or you have to cut off the old balljoints that are riveted on with a hacksaw and a drill and some well placed smacks of a hammer. I would suggest just replacing the control arms because you get new bushings and it would be a much easier job. Remember to get it aligned after you are done.
Old Aug 19, 2009 | 08:45 AM
dandragonrage's Avatar
dandragonrage
I would actually suggest replacing just the ball joints. You only need the drill and a ball joint separator, plus the normal tools (sockets, etc.). Why? Because then you can get a good ball joint like Spicer professional grade. Very beefy.
But it is worth looking at the bushings, too.
Old Aug 19, 2009 | 09:09 AM
f0x672's Avatar
f0x672
#1 you should have the ball joint recall done already on your truck, and #2. replace just the ball joints.. its cake, i should have a previous thread about doing both the lower and upper ball joints on both sides.. had to do all 4 back in april.. took some time but wasnt hard
Old Aug 19, 2009 | 11:31 AM
dublduty's Avatar
dublduty
The lower ones are a bitch to get out if you have no way of heating them. In my past experience, I would take it to a shop and have them press them out. The uppers are simple and take no time at all
Old Aug 19, 2009 | 04:37 PM
f0x672's Avatar
f0x672
... however do not hold heat on those f**kers too long.. they shoot out like a missle when heated for too long... will dent concrete without chipping it
Old Aug 19, 2009 | 07:18 PM
bpark8824's Avatar
bpark8824
Im actually doing mine either tomorrow or friday. But luckely we have a press at work so im not too concerned about it being difficult. I got the Napa replacement ones that are greasable. Hopefully if I keep them greased they will last a lot longer then the first ****ty set. When the recall was done on mine they must of drilled out the revits because mine are bolted in, which makes it that much easier.
Old Aug 19, 2009 | 08:21 PM
f0x672's Avatar
f0x672
good luck dude, sent you a pm.. btw the napa ones are nice, havent greased them yet, except when i installed them. still ncie and stiff
Old Aug 19, 2009 | 08:48 PM
dandragonrage
The uppers are bolted in from the factory on 4wds and riveted on 2wds
Old Aug 19, 2009 | 09:01 PM
bpark8824's Avatar
bpark8824
Ok that make sense.
