Transmission shifting problem
Old Aug 20, 2009 | 11:09 AM
Skullninja500's Avatar
Skullninja500
Default Transmission shifting problem
i have a 2000 dodge dakota 4.7L 4wd
here is my problem
-when shifting into drive there is a delay then hard shift, you can feel it shift
-while driving when it goes to shift from 2nd to 3rd there is also a delay then hard shift
-when going over 45 miles per hour there is a jumpy feeling like lightly taping on the breaks, almost like its jumping in and out of a shift.
a coworker said he had a 2001 dodge ram with these same symptoms and said it was a sensor but cant remember which one
any solutions are helpful
*Edit* ive checked the fluid level, its where its suppose to be
*edit* the only work ive recently done on my truck was get a new powersteering pump, havent done anything to the tranny.
Old Aug 20, 2009 | 12:28 PM
bondslayer's Avatar
bondslayer
Sounds like low trans fluid honestly.
Old Aug 20, 2009 | 09:52 PM
Silver01V8's Avatar
Silver01V8
Did you ever get this figured out? I have a 01 with similar symptoms and would like to know what you found out on this one. Thanks.. And mine is not low tranny fluid.
Old Aug 20, 2009 | 10:20 PM
bondslayer's Avatar
bondslayer
There are only 2 sensors I think on the trans. Have you messed with the tv cable at all, or had any work done for a shift kit or anything to the valve body?
Old Aug 20, 2009 | 10:59 PM
Silver01V8's Avatar
Silver01V8
I just bought the truck and I have not messed with it at all and from looking at it I would say that no one else has messed with the tranny either. The truck is completely un modified.
Old Aug 28, 2009 | 09:42 AM
Skullninja500
still no fix yet......
there has to be someone with the answer
Old Jan 13, 2022 | 09:06 PM
Mudflaps's Avatar
Mudflaps
Default Shifting problem
Check your solenoids in trans pan fixed my jeep
Old Jan 14, 2022 | 10:41 AM
You realize this thread is 12 years old? I would be surprised if he even still has the truck.....
