Swap Help QUICK Please!!!
I have a 97 dakota 4x4 extended cab wih a 3.9 and 42re trans. i got a 318 and 44re trans from a 98 jeep cherokee to swap. igot my 3.9 and trans all out. i also got the computer and wiring harness from the jeep. my motor mounts are the same but one thing is the 44re has wiring with plugs coming off from it and my truc dont have one thing for them to plug into. also on the harness from the jeep about a foot from where it plugs into thecomputer there are to plugs that dont plug into anything in my engine bay. i was told that all i neded for the swap was the motor and trans and computer and wiring harness. this is my daily driver so i have no vehicle right now. i need to get this in asap. please help me. thanks guys
so what year and what vehicle wiring harness and computer should i get to make this whole problem solved? and what harness do i need? just the motor wiring harness or what. is the motor harness part of the trans wiring? i just am so lost
https://dodgeforum.com/forum/2nd-gen...-question.html
Here is a thread i was helping a guy with. Should have some useful info for ya.
You're gonna want...
-Engine wiring harness from 1997 Dakota with 5.2
-PCM from 1997 Dakota with 5.2
If you don't have a local pull-apart junkyard near you i recommend http://www.car-part.com
If u search under my profile you can see the 3.9-5.2 swap i did.
Hope this helps!
Hope this helps!
