Truck sputters and stalls after going through mud
Old Sep 12, 2009 | 11:13 PM
raiders98's Avatar
raiders98
Unhappy Truck sputters and stalls after going through mud
The past few days I have been taking my Dak through some mud, and everytime I do, and the under body gets wet, the muffler starts making a knocking sound, and if it gets wet enough the truck will come to a stop and whenever i try to give it gas the RPMs go down and it feels like its gonna stall. It did stall a few times and took a few seconds to start and i had to give it gas. When I floor it I barely go 2mph. After a while of giving it gas and driving it slowly goes away. Does anyone know the cause of this? My exhaust is dumped right after the muffler, maybe muds getting in it?
Old Sep 13, 2009 | 12:26 AM
magnethead's Avatar
magnethead
do RPM's climb unlinear to speed, like it's hung in neutral, or does the engine bog down like it's super loaded, or is there no throttle response at all?
Old Sep 13, 2009 | 01:32 AM
raiders98's Avatar
raiders98
If it's in neutral or park it revs up almost normal, except sounds like ****. When I put it in drive it feels fine idling but as soon as i give it gas the RPMs go down and I dont go anywhere. After a few minutes it will very very slowly start moving when I give it gas.
Old Sep 13, 2009 | 10:31 AM
RoaminGnome's Avatar
RoaminGnome
Sounds like some electronics are getting wet. Id get under and take a look at everything under there and see if anything stands out. Silicone chalk and heat shrink can help you fix it if thats the problem.
And Ill throw this out there but Id run seafoam thru the gas too. Man I wish I got commission on this stuff lol. Im selling this stuff all over the place
Old Sep 13, 2009 | 01:27 PM
raiders98's Avatar
raiders98
I'll get under there and take a look, thanks alot. Any thing specific I should look for?
Old Sep 13, 2009 | 02:17 PM
NyghtProwler's Avatar
NyghtProwler
I'd start at the after cat O2 sensor.......
Old Sep 13, 2009 | 02:52 PM
RoaminGnome
Id just take a quick peek for something HUGE, like a loose connector or wire with some insulation missing. Then go from there
Old Sep 17, 2009 | 09:38 PM
raiders98's Avatar
raiders98
So I got under and saw some wires that arent covered right before they enter the O2 sensors. Its not exposed metal in the wire, just the wire has no black wrap around it. So I'm gonna cover those. But ever since that happened my truck sounds different. The exhaust doesn't sound as loud and it sounds kinda of ****ty. Any Ideas why?
Old Sep 17, 2009 | 10:10 PM
magnethead's Avatar
magnethead
loose clamp somewhere/exhaust leak?
Old Sep 18, 2009 | 10:23 PM
raiders98's Avatar
raiders98
I think I have a cracked manifold, what would be a good, not too expensive replacement for the 3.9?
