Would this TB work or do I need the other one?
Old Sep 17, 2009 | 11:01 PM
boltonranger2's Avatar
boltonranger2
Default Would this TB work or do I need the other one?
2002 3.9 v6
I found a 1999 5.2 TB locally for 25.
Haven't seen it so not sure what it looks like.
I've heard differing opinions about whether a 50mm is alright or not on the 3.9
What's your experience?
-br
2002 Quad; 3.9 auto_4wd_180 stat_3923's_crank sensor mod_tps@.725
Old Sep 17, 2009 | 11:35 PM
magnethead's Avatar
magnethead
it's called a venturi, without it you lose some bottom end torque. i dont remember what the TB's are, but all are venturi'd by 2 mm.
Old Sep 19, 2009 | 01:31 AM
kurbycar32's Avatar
kurbycar32
a stock 1999 5.2 throttle body should be 48mm, i have that pickup and just upgraded TO a 50mm. I have heard thats a popular upgrade for v6 trucks and for $25 try it, you can resell it on ebay if you dont like it
Old Sep 19, 2009 | 11:17 AM
magnethead's Avatar
magnethead
just make sure to use your V6 sensors, since they're kown good...
Old Sep 19, 2009 | 05:58 PM
Dak4Life's Avatar
Dak4Life
where would i get a larger bored one at? i also have the 5.2.
Old Sep 19, 2009 | 06:04 PM
Dak4Life's Avatar
Dak4Life
also can i find something larger at a junkyard that'll fit....?
Old Sep 19, 2009 | 06:11 PM
magnethead's Avatar
magnethead
no. 5.2 and 5.9 use the same 50mm? throttle body (if you look at the casting, it says V6 or V8 at front right). Also, stockers are made by Holley.
V6 is 48mm i think?
Old Sep 19, 2009 | 06:28 PM
Hahns5.2's Avatar
Hahns5.2
V6 is 48mm i think?
5.2/5.9s use 47mm stock.
The V6s use 39mm.
According to this guy who ports and sells stock throttle bodies (including mine).
http://www.dakota-durango.com/forum/...30&postcount=2
Old Sep 19, 2009 | 11:39 PM
magnethead's Avatar
magnethead
The V6s use 39mm.
I didn't think they were that far apart?!?!
Old Sep 20, 2009 | 07:44 PM
kurbycar32's Avatar
kurbycar32
i got a bored out 50mm throttle body from this guy:
http://www.thefastman.com/
way cheaper than a new one from scratch and being in a pollution controlled state having it look stock was important to me.
