air/fuel ratio gauge
Old Sep 23, 2009 | 12:00 AM
moparman_2004's Avatar
moparman_2004
Thumbs up air/fuel ratio gauge
has anybody installed a air/fuel gauge on the 4.7l i hooked mine up and it reads super super rich as in maxed out i know i need to hit the wire with a volt meter to see if it is the 02 sensor or the gauge i finally got my b pillar and need to get the gauges hooked up
Old Sep 25, 2009 | 02:46 AM
Crazy4x4RT's Avatar
Crazy4x4RT
To me sounds like you got a wire problem. Post up some pics! I had one installed on my truck, but it is not worth it because the computer is constantly changing. I took mine off and installed it in my Dragstrip TA. Where it will do better.
Old Sep 25, 2009 | 11:43 AM
00DakR/T's Avatar
00DakR/T
Does your PCM have three plugs or four? I think on the four-plug ones (NGC) the o2 sensor signal is a 2.5 - 3.5V signal instead of a 0.1-1.0V signal which is probably what the gauge needs. I may be wrong however.
Old Sep 25, 2009 | 12:19 PM
moparman_2004
that sounds very plausable ill i will check that today and do they make air/fuel gauges for this set up
Old Sep 26, 2009 | 12:29 AM
00DakR/T's Avatar
00DakR/T
I think most of the narrow band o2 sensors, like the ones with the sweeping LED's are set up for 0-1. I need to get a wideband for mine, not only because of the blower, but anybody with EFI can't really get an accurate reading without one.
