5.2 to 5.9l swap help please witch harness and computer to use
Old Sep 30, 2009 | 06:58 PM
egzo04's Avatar
egzo04
Default 5.2 to 5.9l swap help please witch harness and computer to use
I have a 97 dakota with the 5.2 4x4 with a bad trans, well I found a 2000 durango 5.9l swap 4x4 also with complete motor trans and harness with computer, will the harnesss and computer work from the 00 durango in my 97 dakota?
Old Sep 30, 2009 | 07:48 PM
00DakR/T's Avatar
00DakR/T
Assuming that your Dakota does not have a sentry key (grey head key) and the Durango does not have a sentry key, it should be pretty much plug and play. You might have a problem if you didn't have the Durango computer, but since you do, I would say you are good to go.
Anybody chime in if I am mistaken...
Old Sep 30, 2009 | 08:03 PM
egzo04's Avatar
egzo04
Ok and the transmission will fit in the same like the 4wheel drive shifter?
Old Sep 30, 2009 | 08:08 PM
00DakR/T's Avatar
00DakR/T
As far as I know. The Dakota/Durango is *******ly identical in drivetrain layout. There will be some small variation in trannys because I don't think the 5.2 uses a 46re like a 5.9 does.
Old Sep 30, 2009 | 08:38 PM
egzo04's Avatar
egzo04
So what are my options if the durango had the chipped key? Swap the harness with my 5.2 harness and use the same computer?
Old Sep 30, 2009 | 08:42 PM
00DakR/T's Avatar
00DakR/T
If the Durango had a chipped key, the computer wont do you much good unless you can get the key, ignition switch, and sentry module from the Durango. The Durango computer will be looking for a key signal when you attempt to start it. I do think that the 5.2 and 5.9 engine programming are the same, so the 5.2 computer should work. I can't say for 100% tho.
Old Oct 1, 2009 | 09:44 AM
egzo04's Avatar
egzo04
Ok so ithey said trhey got the computer and its not a chipped key, all the clips will clip in it fine from 97 to 00?
Old Oct 1, 2009 | 09:46 AM
00DakR/T's Avatar
00DakR/T
In that case, as long as you use the 00 computer and harness, you oughta be good to go.
Old Oct 1, 2009 | 02:48 PM
varsis's Avatar
varsis
You can probably even use the 5.2 computer. Also check it has the same style dash If I were U i would keep your 5.2 harness and computer and match it up to the 5.9 The only difference will be a different air to fuel mixture as long as your computer can do that your set.
Old Oct 1, 2009 | 03:16 PM
egzo04's Avatar
egzo04
Will all the sensor chips be the same from both motors?
