What gear lube for the 8.25"?
Old Oct 5, 2009 | 10:49 PM
beefjerky's Avatar
beefjerky
Default What gear lube for the 8.25"?
75w90 or 75w140? What brands are recommended, or does it not really matter?
I don't have an owners manual, so I apologize.
Old Oct 5, 2009 | 10:53 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
75w-90. even though i have 80w-90 in my truck right now.
Old Oct 5, 2009 | 10:59 PM
dodgerules86's Avatar
dodgerules86
Technically, the tech data calls for 80W-90. 75W-90 will cause no harm.
I think I've used 75W-140, but I'd just stay with 75W-90.
As far as brand, I personally would go with something like Mobil 1, Amsoil, or Royal Purple. But you really shouldn't have any problems with any other brand.
Remember that if you have a limited slip differential, to add friction modifier unless the fluid SPECIFICALLY states it has the modifier in it. (an easy way to know if you have limited slip differential is to jack the back of the truck up and spin one tire. If they BOTH spin the SAME way, you have limited slip. If they spin DIFFERENT ways, you have an open differential and do not need to worry about the additive)
Old Oct 5, 2009 | 11:31 PM
beefjerky's Avatar
beefjerky
Thanks guys, I'll be changing this tomorrow. Hopefully I don't screw up the gasket or anything..
Old Oct 5, 2009 | 11:40 PM
tamcnally's Avatar
tamcnally
when i took mine apart there wasnt even a gasket in there. it was just anerobic sealer all the way around, but i put a gasket in it. it was like 3 bucks at auto zone.
Old Oct 6, 2009 | 01:59 AM
CSCustomCars's Avatar
CSCustomCars
Is 80w-90 the proper weight for a 9.25 as well?
Old Oct 6, 2009 | 03:55 AM
dodgerules86
As per the 2001 service manual:
Lubricants should have MIL-C-2105C and API GL 5 quality specifications.
Front Axle (C205F, 7.562in): 80W-90
(They switched to the C205F from the 7-1/4" in 2000 I believe; the 7-1/4" was 80W-90 as well. The CV joint on the 7-1/4" is held to the axle with bolts about 5 or 6 of them, the CV joint on the C205F is actually slid into the axle)
Rear Axle: 8-1/4" gets 80W-90 and the 9-1/4" gets 75W-90.
It's noteworthy that in 2005 (Gen 3 Dakotas), the recommendations went to 75W-90 for the C205F, and Synthetic 75W-140 for both the 8-1/4" and 9-1/4" rears.
Old Oct 6, 2009 | 02:49 PM
CSCustomCars
Dodge Rules, I'm gonna quote you copy and paste that into my thread Fluid Capacities. It has all the fluid capacities of the Dakota but the dealer never gave me the what weight oil to use in the axles and it's a popular question. If you don't want to me quote you PM me and I'll remove it.
