O2 sensor removal
O2 sensor removal
Hi everyone
I bought an 04 Dak 3.7L with 112,000 Km 2 months ago. This thing is a real gas guzzler with a 75% highway average of 18L /100Km or 13 miles/gal. After reading several posts here, I decided to try cleaning the O2 sensors. No dtc's registered after scan. But when I got under the truck, I can't even access the wiring plugs to disconnect the 4 sensors. They are located in some cramped space above the tranny. Any special trick to disconnect them?
Also, upon checking the relay and fuse box under the hood, there is a space for an O2 relay. Should there be a relay in there? I am thinking the previous owner took it out so it would not light up the CEL when I purchased it.
Any help would be greatly appreciated. Thank's
Don
Don
all i can say is good luck trying to remove those suckers. I tried for about 2 weeks finally got one out with about half a bottle of WD 40 but then i couldn't get to the wire connection. A stupid design by dodge IMO. maybe if you have a lift it would be easier.
A shop wanted like 300 bucks to change them all. I said no thank you, ill deal with the bad mpg.
I removed the left post cat O2 today for cleaning and testing and it was fine. I was finally able to disconnect it. Purchase an O2 socket but no space for it to fit properly. I was not strong enough to budge it with my 7/8 wrench. I finally tied a ratchet tie down to the wrench and the tab and held the wrench in place while ratcheting the tie down. Worked like a charm and still have all my knuckles intact. Will let you know when I figure out how to remove the other 3.
Don
Don
