bellhousing/tranfer case separation
Old Oct 30, 2009 | 06:24 PM
David13's Avatar
David13
Default bellhousing/tranfer case separation
i have a 2002 dodge dakota 5-speed and i need to separate the bell housing from the gearbox. I have all the bolts out and was able to separate them about 1/4 inch but they will not move any further
Old Oct 30, 2009 | 11:07 PM
Hahns5.2's Avatar
Hahns5.2
A bellhousing is on the transmission and it bolts to the engine and houses the clutch/torque converter and your transmission does not have a removable one.
So are you saying you've unbolted the t-case from the tranny but it won't move back more than 1/4" inch?
Old Oct 31, 2009 | 09:10 AM
David13's Avatar
David13
no i miss typed i need to separate the bell housing from the gearbox. i have aready pull the whole transmission out just can't seem to separate the two
Old Nov 1, 2009 | 01:12 AM
magnethead's Avatar
magnethead
the bell housing and gearbox casing, as hahn said, should be one piece.
Old Nov 1, 2009 | 02:17 AM
Hahns5.2's Avatar
Hahns5.2
Correct, the bellhousing itself does not separate from the transmission, it integrated into the front half of the case. Now that you've revised your post I seen you mean you're trying to split the tranny.
Here's an exploded view.
http://www.drivetrain.com/parts_cata...ustration.html
I highly suspect it's the shift rails holding it together.
