Lowering Kit?
theres many ways to lower these truck
me personnaly im doin 3inch custon machined drop blocks with titanium U bolt for strength from axle wrap from my rebuild v8, and 2 inch lowering spring and new shocks all around
theres airbags, aftermarket A-arms, drop shackles, etc...
and for a real cheap way to lower it, you could install a v6 suspension under a v8 truck(if you have one)
Axle wrap is actually misnamed. It isn't where the axle housing rotates in relation to the leaf springs, it is when the leaf spring itself twists into an "S" shape. When that happens, the spring points the pinion upward, and if it points it far enough, you can snap your u-joints and throw the driveshaft out. Anyway, my point is stronger u-bolts won't help against axle wrap, only some form of a traction bar will help, so if you're going with 3 inch blocks, you should also buy or fabricate traction bars.
as for traction...my cousins zq8 sonoma had a third shock in top of the axle that ran parelle to the frame and kept the alxe from wrapping under hard starts...im gonna most likely buy one shock from NAPA and just make my own brackets
my old blocks are aluminum and grade c U bolts so im upgradeing to billet steel blocks and titanum bolts
Trending Topics
but then.. you dont have enough power to ground to cause an issue......
see that why i just want to just add the one shock and see if that helps
hahahahah kidding
