View Poll Results: Myth Or Fact
Fact
29.41%
Myth
70.59%
Voters: 17. You may not vote on this poll
Fact or Fiction
Old Nov 6, 2009 | 04:15 PM
Billiam's Avatar
Billiam
Default Fact or Fiction
Once you go full synthetic you cant switch back to regular oil?
Lets see some answers... I wanna see what you peeps think.
Old Nov 7, 2009 | 12:43 PM
Crazy4x4RT's Avatar
Crazy4x4RT
To my knowledge MODERN synthetics are very flexible with conventional oil. Can be swapped back and forth, can be mixed with it. And will not harm the engine if not designed for it. The Old synthetics are the ones that cause all the problems.
Old Nov 8, 2009 | 08:57 PM
bpark8824's Avatar
bpark8824
My grandfather has owned his own shop and been a mechanic for 40 years and hes always said its not a good idea. Not that 5 miles down the road after you switch that your motor is going to gernade, but that its not a good idea. I don't know a lot of the technical science behind it, but that its not a good idea. Also it may be like Crazy said hes been under this influence since the old days and that now in days it may be ok. But I guess if it were my truck I wouldn't go back and forth. If you ran it at one point, just stick with it.
Old Nov 9, 2009 | 05:33 PM
moparman_2004's Avatar
moparman_2004
i wouldnt swap back and forth every time you change the oil its ok to go synthetic from conventional and stay there or conventional to synthetic id go one way and stay there but its your truck i wont tell you how to run it or what to put in it
Old Nov 9, 2009 | 07:13 PM
Billiam's Avatar
Billiam
I already know the answer. I'm just looking to see what other opinions are.
Old Nov 9, 2009 | 07:46 PM
tamcnally's Avatar
tamcnally
From: Salisbury, Vermont (home) - Lima, Ohio (school)
you can do it. plain and simple. i do it all the time.
Old Nov 10, 2009 | 09:42 AM
bpark8824's Avatar
bpark8824
Please enlighten us then lol.
I'm sure its ok to do. But I wouldn't. If you're going to run synthetic, stick with it. Its better for your engine anyway.
Old Nov 10, 2009 | 12:26 PM
Billiam's Avatar
Billiam
Originally Posted by tamcnally
you can do it. plain and simple......
Right here. Its the answer. Only I don't do it. When I decide to do the switch, I'll be keeping it in there. It has more benefits then conventional...
Old Nov 10, 2009 | 01:34 PM
bpark8824's Avatar
bpark8824
Is it true though, that with older oils it wasn't something that should be done? Because its been one of those myths thats been around forever. Is it based on old school oils and there have been changes to the oils over the years?
Old Nov 10, 2009 | 02:18 PM
Billiam's Avatar
Billiam
I would assume so. The advances in older oil to today's is different. My guess is Crazy is correct on that part too.
