2000 Dakota question
I can't get a straight answer from anyone.
On a 6 cylinder is is possible to bypass the AC compressor pump with a serpentine belt for a non AC model?
My compressor is crapping out and I need a quick fix until I can get it fixed.
Will it have any adverse effect if I do?
It may work. But the compressor may be in the way of the belt. Another option is get a AC bypass pulley. This is the one for magnum engines. http://www.autozone.com/autozone/cat...archText=34178
Just so you know the heater system uses the AC to dry the air. This makes defogging your windows much faster.
The belt for the non A/C V-6 is too short for some reason. The A/C pulley is not in the way. Unless some other parts store sells a belt specificly for the purpose of by-passing the A/C pulley then I guess we are S.O.L. I understand there might be a by-pass pulley kit but there. It is probably a new pulley and bracket so that it replaces the compressor and uses its mounting position. This way you use the same belt
to:abnknuck i have a 2001 dakota factory service manual. i lists a pic of the with AC and one with out AC. it has a mistake by listing the wrong engines, but i figured out what it realy is. my e-mail is on the blink. i think i could list my phone no. hear. then we could talk. what think?
