motor questions
Old Nov 12, 2009 | 05:36 PM
rcdak47's Avatar
rcdak47
Default motor questions
i have a 04 dakota with a 4.7,i wanna go faster so should i:
1.stroke the 4.7 and build it up
2. swap it with a 5.9 or a 5.7 hemi (and if i swap, how hard is it to do?)
Old Nov 12, 2009 | 06:21 PM
RoaminGnome's Avatar
RoaminGnome
Well first off what are you lookin to do? Drag, off-road or just more power, thats the first bit.
Personaly I would build your 4.7. Or at least look into the laws and such for a swap. Id have LOTS of hoops to go thru cause mine is OBD2 so come time for fun Ill get a 1st gen to play with
Old Nov 12, 2009 | 06:30 PM
rcdak47's Avatar
rcdak47
true, Im looking to build it for the track, if i do a 5.9 its getting stroked to a 408 and if a 5.7 i havent figured out what id do for that yet. But i would like to get into the 11's or low 12's with or without a supercharger
Old Nov 12, 2009 | 10:29 PM
Independentfool's Avatar
Independentfool
im all for more power. but if you are wanting speed, buy a car. Our trucks are on the heavy side to begin with.
Old Nov 12, 2009 | 11:04 PM
dodgeramguy85's Avatar
dodgeramguy85
personally I would do the hemi or my second choice is the 5.9. Swapping them really depends on your skills you need to make different mounts and what not. stroking the 4.7 is def the easiest way to go
Old Nov 13, 2009 | 12:15 AM
dbilik's Avatar
dbilik
I have never seen a kit out there to stroke the 4.7. Have a link? I know the HO version has a better crank and cams. You can upgrade to high performance bearings and pistons. But it isn't cheap.
For the money I would put a hemi in if you can track one down.
Old Nov 15, 2009 | 06:59 PM
rcdak47's Avatar
rcdak47
yea true just swaping to a differnet motor is alot of work and money and a company was gonna make a stroker kit but its still up in the air.
Old Nov 15, 2009 | 08:37 PM
RoaminGnome
Well I was gonna start gathering bits and info for a cummins swap but I am unsure bout the laws and what not. So Ill just do that to a 1st gen
Regardless of what you do do it right and keep us updated and PICS PICS PICS!!!
Old Nov 16, 2009 | 11:16 PM
Independentfool
swapping a Cummins in a Dakota is a huge undertaking! Look up the Banks Dakota for some info.
Old Nov 17, 2009 | 09:02 AM
bpark8824's Avatar
bpark8824
The chances of you getting into the 11's w/out any power adders isn't good. The easiest thing would be building your 4.7. But w/ the amount of aftermarket support you're not going to get too far with it. Just cams, pistons, (I don't know of a stroker kit), headers, true duals, intake, superchips... But even with all that your not close to 11's. You will need to putting down close to if not more then 500 to the wheels to break 11's. My uncle had a 98 vortech s/c'ed cobra with 460hp to the wheels and it was a low 12 second car that weighs ~6-700 lbs less then your truck.
A fully built 408 will probably get you close though.
But getting the hp is only half the battle. Once you finally do obtain 500hp, now you have a whole lot of other things to deal with. Tranmission, suspension, and the fuel system will all need to be upgraded to handle 500 hp. Our trucks were in no way intended to make that kind of power. You will never make it down a strip on the stock suspension and your transmission will be laying in the road after a couple passes with that power. Plus the stock injectors and fuel pump would be able to keep up.
Its a HUGE undertaking to take a truck with 200-215 to the wheels and make it into an 11sec drag vehicle. I'm not saying it can't be done, but think about everything that has to go into it to get that truck into that kind of bracket.
