Lift question.
Old Nov 20, 2009 | 07:19 PM
cbr600rx7's Avatar
cbr600rx7
Default Lift question.
Ok hold off on the "did you search for just one second" If this sounds like a noob question i dont mean it to be.
I am looking at buying new tires BFG TA's and there is a very small price diffrence from the 31 x 10.50 to the 33 12.50. Since i do a lot of hunting and drive on the beach in the summer the wider tires would be a great. But reading the FAQ it says that 31s are the biggest i can go on a stock truck. Looking at the wheel gap right now with 31s on the truck there is a ton of wheel gap and i think i could fit 33s under there the way it sits from the looks of it. But just to be safe i was thinking of building a 1-1.5 inch body lift to keep it from rubbing when i go over big bumps. To do this i was just thinking of cutting some 1/4 inch strips to make a block to put over the rear axle under the leaf. And for the front welding 4 of the 1/4 inch pieces together to make one inch blocks for the body mounts.
2000 Dodge Dakota crew cab 4x4 sport
Flame on .
Old Nov 20, 2009 | 09:35 PM
Jdb107's Avatar
Jdb107
lots and lots and lots and lots of these posts already
31 is the largest you can fit on stock without rubbing
33s you need a 2" body lift, and I think if you crank the wheel (depending upon rim thickness and tire tread) you still may have a little rub
search
Old Nov 20, 2009 | 09:41 PM
Jdb107's Avatar
Jdb107
http://www.4wheeloffroad.com/techart...ide/index.html
Old Nov 21, 2009 | 02:03 AM
cbr600rx7's Avatar
cbr600rx7
I agree and i have done a few searches. Sorry i am a little lost with all the diffrent set ups out there and since tires alone will run me about 600 bucks i cant go all out with real suspension lift and i dont want to sacrifice the on road ride.
I did find this on ebay. I am personaly not a big fan on buying items i dont know any thing about off ebay but too me it looks and sounds good.
http://cgi.ebay.com/ebaymotors/3-Sus...Q5fAccessories
Old Nov 21, 2009 | 02:15 AM
cbr600rx7's Avatar
cbr600rx7
Also a lot of the tire guids are not all that correct. Close yes and most of the time they are right. But not every time.
For example that one says a 83-92 bronco II/Ranger needs 2-4 inches of lift for 31s Bronco II/Ranger83-92 . I just sold my 88 ext cab ranger and had 31 MT's on a bone stock truck.
Not saying this is the case here as i take your word. But you see why i ask on forums too. And i will admit i should search a little more to start with but i am a little lost and dont want to waste my money and time with the wrong set up.
Old Nov 21, 2009 | 04:03 AM
Jdb107's Avatar
Jdb107
im pretty sure its accurate for the dakotas;
now i cant confirm it 100% but with a 3" body lift and 10" wide tires or less you can fit 33s without rubbing
theres a bunch of people kicking around on this forum with body lifts that im sure will answer in the near future
Old Dec 9, 2009 | 04:32 PM
wingerak92's Avatar
wingerak92
So, back on this topic, I'm hoping for people with body lifts to chime in here. I am looking for one and found this one:
http://www.summitracing.com/parts/PRA-PA-60043/
Anyone have experience with performance Accesories?
It seems to come with everything required, I also have the tow package so it wouldn't affect my towing, would it?
Old Dec 11, 2009 | 12:04 AM
wingerak92's Avatar
wingerak92
anyone?
i got a big bonus cheque coming up here. Want to spend it lol
Old Dec 11, 2009 | 12:30 AM
primus454's Avatar
primus454
I have a 3" body lift and a set of 33x12.5. They look GREAT. Only rub a very small amount at full lock. I have them on Cragar soft 8s. Only one size (I think) available at Summit for our bolt pattern.
Old Dec 11, 2009 | 02:29 AM
wingerak92's Avatar
wingerak92
Is your body lift the Performance Accessories one?
Also, it won't affect my towing if I have the receiver hitch?
As well as ride issues?
Long term effect on steering column?
