quick tire question
Old Nov 23, 2009 | 02:29 PM
DuckandDodge's Avatar
DuckandDodge
Smile quick tire question
hey guys, right now im in need of some new tires right now i have P255/65R16 (29 in. tire) and im thinking about going up to a P265/75R16 (31in tire) do you guys think these would fit under a 2001 qc with the stock height? the only thing i would think would be a problem would be a little rubbing?
thanks
Old Nov 23, 2009 | 02:42 PM
thunder98110's Avatar
thunder98110
look in the sticky section or search the forum. this gets asked every other day.
Old Nov 23, 2009 | 03:21 PM
DuckandDodge
searched the stickys says can only stay with the stock tire size with the stock height? I very seriously think i could fit another inch or two under there. im not worried about the back, i can just go down to autozone and buy some blocks for like $40 but i am worried about the front? think if i cranked the torsion bars a bit they would fit?
Old Nov 23, 2009 | 04:35 PM
dodgeramguy85's Avatar
dodgeramguy85
if its a 2wd it wont fit If it was 4x4 then it would my 98 4x4 came from the factory with 31's
EDIT sorry didnt see your sig but its not going to fit without a lift
Old Nov 23, 2009 | 07:19 PM
magnethead's Avatar
magnethead
don't get the throttle body spacer FYI.
Tire wise, I have 3's under mine (265/55 or thereabouts), and I've chewed up the sidewalls pretty good from bottoming out. But the plastic inner fender just moves out of the way, and steering is fine lock to lock.
Old Nov 23, 2009 | 11:41 PM
DuckandDodge
alright guys, thanks for the input.
Old Nov 29, 2009 | 01:26 PM
DakotaDRVR's Avatar
DakotaDRVR
Not to discourage your decisions on the tires but Ive run bfg A/Ts twice and both times they wore fast. They are a great tire and I would run them again but I wouldnt buy a set. If youre goin for looks thats an expensive look. General tires carry similar tires which I believe are cheaper. And they have been on my truck for 2 years and Im just gettin to the point I have to change them for winter. If youre looking for performance then there are certainly better cheaper tires. Try Ebay and Craigslist, sites like that.
*as for puttin the 31s on, go for it. I ran 30x9.50s on my 4x4 and had no problem so I went to a 32x10.50 and had minor rubbing. Truck still drove fine. Also you can pick up a lift kit or make your own for REAL cheap. Look into it and let me know.
Old Nov 29, 2009 | 03:50 PM
dodgeramguy85
Im running bfg a/t's on my dak and I love them Im going to buy them again. I know 3 or 4 other people that have them that also love them and they are wearing great. I even lay a little tire every now and then and my back ones still have about the same amount of tread as all the other ones do
Old Nov 29, 2009 | 06:11 PM
Mean Green's Avatar
Mean Green
My BFG's have a little under 50K miles on them and are almost to the point of needing replacement they will make it to the 55K mile mark easy. Just rotate them, keep the truck aligned and try not to do so many burnouts.
Old Dec 3, 2009 | 11:02 AM
2000DakotaOwner's Avatar
2000DakotaOwner
Default 31" tires
I have 31x10.5-15 AT tires on factory wheels. No rubbin or scrubbin at any angle or index.
2000 Dakota Crew Cab 4x4
