Need help
Old Dec 13, 2009 | 12:58 PM
Crazy4x4RT's Avatar
Crazy4x4RT
A cat back system replaces everything from the CAT (Catalytic converter) all the way BACK. Extreamly simple term.
Old Dec 13, 2009 | 09:20 PM
sideASS's Avatar
sideASS
oh ok cool cool, i understand you now. And yeah i dont really know which one i like yet ill have to go check out those sound clips. I looked at the headers also but thats pretty exspensive in my case so i dont think im gonna go that route. Oh and about the dual, ya i wanna go with that for sure.
Old Dec 13, 2009 | 09:24 PM
thunder98110's Avatar
thunder98110
true if you buy from gibson or jba ect. if you look at summitracing you can get a set for under $250. maybe not as flashy or name brand but will do the same thing.
Old Dec 14, 2009 | 04:51 PM
sideASS's Avatar
sideASS
oh really? ill have to check that out also
Old Dec 14, 2009 | 05:25 PM
chris1974's Avatar
chris1974
yep. I've already got a pair picked out for my truck....
Should I send someone a link so they can buy them for me?? Pweeeeaassseee?
Old Dec 14, 2009 | 05:44 PM
sideASS's Avatar
sideASS
oh yeah sure ill just buy yours when i buy mine haha. Ok one more question. How do i know which headers and cams to get? like wats the difference in all of them? like the different types
Old Dec 14, 2009 | 05:58 PM
chris1974's Avatar
chris1974
as far as headers go...I don't know that there is that much difference between them (someone correct me if I'm worng here). The whole idea about headers is to just get unrestricted air flow out of the engine....so headers that have less curves and are shorter would be better than something that has alot of bends, or sharp curves. Becuase afterall, an engine is actually a big air pump. The faster you can bring air in, and get it out, the more power you will make.
As far as cams go....you have a few different choices. I would just suggest doing some research on them. Cams are a little too technical for me to go into (plus I'm about to leave work haha) Here is probably a good place to start. Mopar Muscle Magazine...understanding cam specs... http://www.moparmusclemagazine.com/h...ecs/index.html
Hope this helps....
Old Dec 14, 2009 | 07:02 PM
batman13's Avatar
batman13
one tip, if you get stainless steel headers, make sure you wrap them in heat wrap or get them ceramic coated,
they will get HOT,
unless you dont have much near the headers like me but you're truck has a lot more under hte hood
Old Dec 15, 2009 | 12:51 AM
dodgeramguy85's Avatar
dodgeramguy85
I prefer magnaflow but thats just me I have dual 2.5 inch cat back setup on my 98 and it wasnt all that loud at first but then after a little bit of driving it started to get louder and now it sounds great. This is what it sounded like as of aug 09
http://www.youtube.com/watch?v=C5q3QtdxVpM
Old Jun 17, 2010 | 02:53 PM
sideASS's Avatar
sideASS
Default so far
Alright its been awhile since i've posted this thread and so far for my exhaust i yanked the CAT out and just took it straight back from the headers with 2 flowmaster mufflers, and also put a throttle body spacer on. And next im probably doin the cold-air intake but cant decide on which one to do between the CgS intake, the AEM brute force, or aFe. The next will come either the programmer or piggyback module idk which route to go on that. Then as far as exterior goes i put a 3" body lift and im custom building 2-way swing arms and slappin on some procomp nitrogen loaded shoxs w/ reserviors that are made for alot taller trucks and we are just gonna cut holes in the hood and have them stick through and finally i just got in my BF Goodwrinch all-terrains (33") and 16" procomp wheels
