lights behind heat/ac controls
Old Mar 28, 2011 | 03:52 PM
  #41
thunder98110's Avatar
thunder98110
http://www.superbrightleds.com/cgi-b...nstrument.html
they are under the "twist lock" section. first ones
Old Mar 28, 2011 | 04:05 PM
  #42
moparman_2004's Avatar
moparman_2004
ok so i hope i got it right now you need the neo-x5 for the a/c and how many of them is there and did you get the 2 lumen or the 5 lumen ones then for the instrument cluster you use the WLED-xHP5 and how many of these and you use the same for the turn signals or were those a diffrent bulb also sorry about all the questions im in baghdad it makes it hard to just go and check but want to get them ordered
Old Apr 9, 2011 | 02:30 AM
  #43
Blaze10's Avatar
Blaze10
im confused on which ones you need for behind the ac control. i just got this 2004 and i wanna replace them all the gauges and the a/c control because the a/c control ones are blown, i am thinking there is only one lit up because the part where you put it on defrost and or put it to upper and lower or just lower like that switch is completely black, no light at all so how many do i need and which ones on superbrights website
Old Apr 9, 2011 | 06:48 AM
  #44
moparman_2004
nice you got pics of the 04 yet
Old Apr 9, 2011 | 08:38 AM
  #45
cowboy63645's Avatar
cowboy63645
I just replaced the lights behind my A/C panel with the NEOx-xHP 6 lumen 5mm blue LED. It takes 3 of them.
Old Apr 9, 2011 | 11:51 PM
  #46
Blaze10's Avatar
Blaze10
did you get the twist and lock sockets?
Old Apr 10, 2011 | 10:53 AM
  #47
cowboy63645
No, the lights behind the A/C panel do not require the twist lock because on the lights for that particualr board they are a built in twist lock.
Old Apr 11, 2011 | 12:56 AM
  #48
Blaze10's Avatar
Blaze10
oh ok! thanks for all the help
Old Apr 11, 2011 | 10:28 PM
  #49
ebrperk's Avatar
ebrperk
Cowboy, are the lights any brighter??
Old Apr 12, 2011 | 01:35 AM
  #50
cowboy63645
yes, they are a little brighter, but not enough to be blinding, and they are a nice change from all the green.
