New Fuel Rails Installed.
Finally ordered the crap to install my fuel rails.
2x 120degree -8an fittings double swivel
2x 90degree NPT > -8an double swivel
1x Male NPT to -6an female adapter
1x -6an fuel line connector
3foot of Steel Braided Hose.
Made my crossovers, and put Permatex Gel (BLUE) lock-tight on all the fittings, checked for leaks and everything looks fine, also put on my fuel pressure solenoid so now i can monitor it via the cab what my fuel pressure is. Will come in handy in the future.
Not hard at all, idle is totally different, start-up is super fast, and low end rpm bog is illiminated due to a hotter and better spark which burns all the fuel. You will need to gap your plugs a tad bit bigger for the larger spark.
I used the Factory replacement coil by msd.
http://www.summitracing.com/parts/MSD-8228/ (COIL)
http://www.summitracing.com/parts/ACC-140021AH/ (ADAPTER FOR COIL)
http://www.summitracing.com/parts/MSD-6200/?image=large (MSD 6A Box)
http://www.summitracing.com/parts/MSD-8910/ (TACH ADAPTER for CELS)
IMO worth the money.
Power in general? Its an ignition system not a supercharger. If you have a lot of mods it works fine, putting it on a stock vehicle you will not notice much difference in POWER.
If your looking for power, i would go headers, tb, intake manifold, rockers, exhuast, intake, cam, heads, ect... MSD just helps bring everything together. Look at what they claim on there site...
MSD does add more power due to a better combustion, due to the hotter spark, but its not going to be a lot.
The Air Filter i got from summit...
http://www.summitracing.com/parts/DC...7/?image=large
Trending Topics
Mkay, exhaust before MSD it is. I already have the throttle body taken care of and plan on getting rockers within the week so its a start
Yea, I'm getting the 1.7 HS rockers. How much did you notice from them? Consensus seems to be 10rwhp.
. Yea, I'm getting the 1.7 HS rockers. How much did you notice from them? Consensus seems to be 10rwhp.
1.7s raise your lift, increasing the valve opening letting in and out more air. The better your other mods are, the better the rockers will work.
While your installing the rockers i would upgrade to some stouter springs and replace the valve seals while your in there.
