'01 Fog Light Mod?
Old Dec 29, 2009 | 10:10 AM
DennisCon's Avatar
DennisCon
Default '01 Fog Light Mod?
I have given up searching for a relevant thread...
Please point me to, or provide, info on setting up the Dak to keep foggies on with hi-beams. All I have found is the relay jumper mod for earlier or different models.
Please save your ranting about "appropriate use" of fog lights - out here, in the sticks, we need all the light we can get on our unlit roads. Any little bit of advance warning of that Dakota-slammin' deer in the weeds is a help (fogs can pick up the eye reflection when nothing else will). Those buggers must be suicidal...
Old Dec 29, 2009 | 10:14 AM
thunder98110's Avatar
thunder98110
just buy yourself a pair of auxiliary lights if you wanna light up the road.
Old Dec 29, 2009 | 10:53 AM
DennisCon's Avatar
DennisCon
Auxiliary lights are a someday purchase - I'm trying to work with what I have.
Old Dec 29, 2009 | 11:35 AM
thunder98110
getting a bulb upgrade might be a better option.
Old Dec 29, 2009 | 02:19 PM
batman13's Avatar
batman13
how good are you at wiring?
its a simple mod to do if you have some wiring skills.
the idea is to re-wire your fogs with their own relay to run off the fog switch and not through the headlight switch, i don't have fogs (yet) so i dont know the exact procedure
DennisCon's Avatar
DennisCon
Bump for useful information...
Old Dec 29, 2009 | 02:23 PM
batman13's Avatar
batman13
heres one mod i found, its for a toyota but if im not mistaken the wireing is the same
http://mouser.org/projects/tacoma/foglights_mod/
Old Dec 29, 2009 | 04:39 PM
wewanaplay's Avatar
wewanaplay
Go look in the ram section, there is a lot of usefull info in there that carries over into our trucks as well
Old Dec 30, 2009 | 09:19 PM
DennisCon's Avatar
DennisCon
What I found didn't match what's in mine:
The '01 appears to have a different relay:
(< front, V driver's side)
| <-- this one is dead - no connector
suggestions?
Old Dec 31, 2009 | 05:22 PM
00dakSport's Avatar
00dakSport
Default i moved my fogs for the same reason
if u can't get new lights right now then you can move ur fogs up like i did. i put them behind the grill a little below the head lights. i have some dark roads where i live and with this setup i have'nt needed my brights.
http://i39.photobucket.com/albums/e1...ket/glits2.jpg
http://i39.photobucket.com/albums/e1...glits4good.jpg
another thing that coud help u is a headlight restore kit. 20 bucks anywhere
